  • Release notes
    • 2024.10.8
    • 2024.10.7
    • 2024.10.6
    • 2024.10.5
    • 2024.10.4
    • 2024.10.3
    • 2024.10.2
    • 2024.10.1
    • 2024.10
Process Mining release notes
Last updated Apr 27, 2026
2024.10.1
Release date: December 18, 2024
Data transformations
Dbt projects now run with dbt version 1.8.4. Check out the official dbt documentation to make use of the latest dbt functionalities.
With the introduction of unit tests in dbt version 1.8, the tests: key was renamed to data_tests:. For existing process apps, this results in a deprecation warning that is displayed when loading data or opening Data transformations.
[WARNING]: Deprecated functionality The `tests` config has been renamed to `data_tests`. Please see https://docs.getdbt.com/docs/build/data-tests#new-data_tests-syntax for more information.
For default process apps, you can rename the occurrences of the tests: config to data_tests: in the dbt_project.yml and the sources.yml files to fix this. For customized process apps, this can be present in other .yml files as well.
Check out the official dbt documentation on the New data_tests: syntax for more information.
Process cropping filter
There was an issue when using the Process cropping filter in Conformance checking that an assertion error could occur. This is now solved.
We are constantly striving to improve your UiPath® Process Mining experience. While this release brings no major changes, we included security and accessibility improvements, as well as minor bug fixes.
  • Release date: December 18, 2024
  • Data transformations
  • Process cropping filter
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
