Process Mining user guide
Viewing Process data
Introduction
The Process data dashboard enables you to analyze your data on the lowest level. It contains a different tab for every table available in your data.
Follow these steps to display the Process data dashboard.
  1. Select Process data in the menu on the left of the dashboard.
The Process data dashboard is displayed. You can browse through the tabs to view the data in the different tables.
Selecting display columns
Follow these steps to change the visible columns.
  1. Select Columns to display the list of available columns.
  2. Select the columns you want to display in the selected Process data dashboard from the Visible Colums list.
Re-sizing the table columns
You can change the size of the columns in the Process Data dashboard.
  1. Select the docs image icon in front of a column name.
  2. Drag to reisize the column to the desired size.
Viewing Process details
The Details icon in front of a row enables you to view the details of a selected case. The following illustration shows an example.
The KPIs displayed on top of the Process details page are the same as the columns selected in the parent Process data page.
  • Introduction
  • Selecting display columns
  • Re-sizing the table columns
  • Viewing Process details
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
