- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Kerberos authentication configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Redirecting traffic for the unsupported services to the primary cluster
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 8: Migrating standalone Test Manager
- Upgrading Automation Suite
- Executing the upgrade
- Using the Orchestrator Configurator Tool
- Orchestrator appSettings
- Configuring appSettings
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- How to forward application logs to Splunk
- How to clean up unused Docker images from registry pods
- Test Automation SQL connection string is ignored
- DNS settings not honored by CoreDNS
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Longhorn REST API endpoint upgrade/reinstall error
- Service upgrade fails during pre-service script execution
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Failure to add agent nodes in offline environments
- Accessing FQDN returns RBAC: access denied error
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- After Disaster Recovery Dapr is not working properly for Process Mining
- Configuring Dapr with Redis in cluster mode
- Exploring Logs
- Exploring summarized telemetry
Last updated Apr 22, 2026
Updating the registry credentials
To update the registry credentials, take the following steps:
Update the registry credentials section in the
cluster_config.jsonconfiguration file:"registries": { "docker": { "url": "yourContainerRegistryUrl", "username": "username", "password": "newpassword" , "pull_secret_value": "new_pull_secret_value" }, "helm": { "url": "yourContainerRegistryUrl", "username": "username", "password": "newpassword" } }"registries": { "docker": { "url": "yourContainerRegistryUrl", "username": "username", "password": "newpassword" , "pull_secret_value": "new_pull_secret_value" }, "helm": { "url": "yourContainerRegistryUrl", "username": "username", "password": "newpassword" } }To generate the value for
pull_secret_value, refer to the How to section. -
Re-run the Automation Suite infrastructure installation as follows:
- Re-install the infrastructure on the first server machine. For details, see Step 2: Installing the infrastructure on the first server machine.
- Re-install the infrastructure on the other server machines. For details, see Step 3: Installing the infrastructure on the other server machines.
- Re-install the infrastructure on the agent nodes. For details, see Step 4: Installing the infrastructure on all the agent machines.
Depending on the node type, restart the
rke2-serverorrke2-agentservices on all nodes, by running the following commands:- On server nodes, to restart the
rke2-serverservice, run the following command:systemctl restart rke2-serversystemctl restart rke2-server - On agent nodes, to restart the
rke2-agentservice, run the following command:systemctl restart rke2-agentsystemctl restart rke2-agent
Delete the existing
uipathpullsecretsecret in all namespaces, by running the following commands:kubectl get secrets --all-namespaces | grep uipathpullsecret | awk '{print $1 " " $2}' | while read namespace secret; do kubectl delete secret "$secret" -n "$namespace" ; done ;kubectl get secrets --all-namespaces | grep uipathpullsecret | awk '{print $1 " " $2}' | while read namespace secret; do kubectl delete secret "$secret" -n "$namespace" ; done ; -
Re-run the fabric and services installation. For details, see Step 5: Completing the installation.
