Last updated Nov 13, 2025
GCP Deployment Template
Important: This deployment template is currently deprecated and is planned for removal in October 2025. As an alternative, consider using Automation Suite on EKS/AKS or reach out to support.
Note: You can currently use the GCP deployment template only with Automation Suite 2024.10. We therefore recommend referring to the Automation Suite 2024.10 documentation.
Step
Instructions
GCP deployment architecture
Step 1: Preparing the GCP deployment
Step 2: Deploying Automation Suite to GCP
Step 3: Post-deployment steps
