- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Kerberos authentication configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Redirecting traffic for the unsupported services to the primary cluster
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Using the Orchestrator Configurator Tool
- Orchestrator appSettings
- Configuring appSettings
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- How to forward application logs to Splunk
- How to clean up unused Docker images from registry pods
- Test Automation SQL connection string is ignored
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Longhorn REST API endpoint upgrade/reinstall error
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- After Disaster Recovery Dapr is not working properly for Process Mining
- Configuring Dapr with Redis in cluster mode
- Exploring Logs
- Exploring summarized telemetry
Once a cluster is restored, the snapshot backup is not enabled. To enable it after restore, see Enabling the backup snapshot.
Restoring the cluster does not restore external data sources such as SQL Server, objectstore, or the OCI-compliant registry. Make sure to restore these datasource to the relevant snapshot.
To restore the cluster, take the following steps:
- Install the cluster infrastructure on all the server nodes. The hardware you provide for the restore cluster must be similar to the backup cluster hardware. For details, see Hardware and software requirements.
- Configure the snapshot on the restored cluster.
- Select the snapshot to restore.
- Restore the data and settings.
Preparation
- Download the restore installer. You can find it inside the
as-installer.zippackage. For download instructions, see Downloading the installation packages. - In offline environments, you must provide an external OCI-compliant registry or a temporary registry. Note that the registry
configuration must remain the same as the one of the original cluster. To configure the registry, see the following instructions:
- Configuring the external OCI-compliant registry
- Configuring the temporary Docker registry. Choose this option only if you did not use an external OCI-compliant registry before the disaster occurred.
- Prepare the configuration file and make it available on all the cluster nodes. To prepare the configuration file, take one
of the following steps:
- Option A: Reuse the
cluster_config.jsonfile that you applied to the cluster before the disaster occurred; - Option B: Create a minimal
cluster_config.jsonfile with the required parameters, as shown in the following example:{ "fixed_rke_address": "fqdn", "fqdn": "fqdn", "rke_token": "guid", "profile": "cluster_profile", "external_object_storage": { "enabled": false }, "install_type": "offline or online", "proxy": { "enabled": false } }{ "fixed_rke_address": "fqdn", "fqdn": "fqdn", "rke_token": "guid", "profile": "cluster_profile", "external_object_storage": { "enabled": false }, "install_type": "offline or online", "proxy": { "enabled": false } }
cluster_config.json file. Make sure to provide the same parameter values as the ones used in the orginal cluster. You can change the parameter
values post-restore.
cluster_config.json parameters listed in the following table, you must also provide the external OCI-compliant registry configuration. For details,
see External OCI-compliant registry configuration.
Parameter |
Value |
FQDN of the Automation Suite cluster. The value must be the same as the old FQDN. Providing a different FQDN value may cause the restoration to fail. |
The fixed address used to load balance node registration and Kube API requests. If the load balancer is configured as recommended, the value should be the same value as the one for
fqdn. Otherwise, use the fqdn value of the first server node. Refer to Configuring the load balancer for more details.
Use a newly generated GUID here. This is a pre-shared, cluster-specific secret. It is needed for all the nodes joining the cluster. |
Sets the profile of the installation. The available profiles are:
Indicates the type of installation you plan to perform. Your options are:
This parameter is mandatory only if the proxy is enabled. For details, see Optional: Configuring the proxy server. |
cluster_config.json, see Manual: Advanced installation experience.
Execution
Installing the cluster infrastructure on the primary restore cluster node
To install the infrastructure on the primary restore cluster node, run the following commands:
cd <installer directory>
./install-uipath.sh -i ../../cluster_config.json -o output.json --accept-license-agreementcd <installer directory>
./install-uipath.sh -i ../../cluster_config.json -o output.json --accept-license-agreementcluster_config.json from the primary server node to the remaining server/agents nodes. The infrastructure installation step on the primary server
node adds extra values that the remaining nodes need.
Installing the cluster infrastructure on secondary servers
To install the infrastructure on the secondary servers:
./install-uipath.sh -i ../../cluster_config.json -o output.json -j server --accept-license-agreementcd <installer directory>
./install-uipath.sh -i ../../cluster_config.json -o output.json -j server --accept-license-agreementInstalling the cluster infrastructure on agent nodes
To install the infrastructure on the agent nodes:
./install-uipath.sh -i ../../cluster_config.json -o output.json -j agent --accept-license-agreementcd <installer directory>
./install-uipath.sh -i ../../cluster_config.json -o output.json -j agent --accept-license-agreementInstalling the cluster infrastructure on Task Mining nodes
To install the cluster infrastructure on Task Mining nodes:
./install-uipath.sh -i ../../cluster_config.json -o output.json -j task-mining --accept-license-agreementcd <installer directory>
./install-uipath.sh -i ../../cluster_config.json -o output.json -j task-mining --accept-license-agreementInstalling the cluster infrastructure on Automation Suite Robots nodes
To install the cluster infrastructure on Automation Suite Robots nodes:
./install-uipath.sh -i ../../cluster_config.json -o output.json -j asrobots --accept-license-agreementcd <installer directory>
./install-uipath.sh -i ../../cluster_config.json -o output.json -j asrobots --accept-license-agreementInstalling the cluster infrastructure on GPU nodes
To install the cluster infrastructure on GPU nodes:
./install-uipath.sh -i ../../cluster_config.json -o output.json -j gpu --accept-license-agreementcd <installer directory>
./install-uipath.sh -i ../../cluster_config.json -o output.json -j gpu --accept-license-agreementOnce the infrastructure is installed, configure the snapshot while providing the minimum data, such as target, endpoint, and location. These values are used at the time of restoration.
To configure the backup of the restored cluster, follow the steps in the Configure the cluster snapshot section.
After configuring the snapshot, list the existing snapshots and decide on the one you want to use as a restoring point.
--from-snapshot <snapshot-name> flag.
./configureUiPathAS.sh snapshot restore create --from-snapshot <snapshot name>./configureUiPathAS.sh snapshot restore create --from-snapshot <snapshot name>If you do not specify the snapshot name, the cluster restores the latest successful snapshot. See the snapshot list for available snapshots.
Restoring cluster_config.json
cluster_config.json file for future usage, such as adding new nodes to the cluster, upgrading, etc.
cluster_config.json:
./bin/uipathctl manifest get-revision >> ./cluster_config.json./bin/uipathctl manifest get-revision >> ./cluster_config.jsonAdding CA certificates to the trust store
After restoring the cluster, make sure to add your CA certificates to the trust store of the restored VMs. For details, see:
Retrieving new monitoring password
After restoring an Automation Suite cluster, you need to retrieve the new monitoring password. For this, follow the steps from Accessing the monitoring tools.
Enabling AI Center on the Restored Cluster
After restoring an Automation Suite cluster with AI Center™ enabled, follow the steps from the Enabling AI Center on the Restored Cluster procedure.
Generating new Kerberos ticket
If Kerberos authentication is set up, you must make sure that the Kerberos ticket is not expired.
To generate a new Kerberos ticket, run the following commands:
kubectl get cronjobs -A | grep kerberos //to identify the job with name kerberos-tgt-update
kubectl create job --from=cronjob/<cron-job-name> <new_job_name> -n <namespace>kubectl get cronjobs -A | grep kerberos //to identify the job with name kerberos-tgt-update
kubectl create job --from=cronjob/<cron-job-name> <new_job_name> -n <namespace><cron-job-name>, <new_job_name>, and <namespace> with the actual name of your cron job, the intended name for the new job, and your actual namespace respectively.
- Step 1: Installing the cluster infrastructure
- Preparation
- Execution
- Step 2: Configuring the snapshot on the restored cluster
- Step 3: Selecting the snapshot to restore
- Step 4: Restoring data and settings
- Restoring cluster_config.json
- Adding CA certificates to the trust store
- Retrieving new monitoring password
- Enabling AI Center on the Restored Cluster
- Generating new Kerberos ticket
