Last updated Nov 6, 2025
Disaster Recovery: Performing post-installation operations
Generating the kubeconfig file of the cluster
The generated kubeconfig file must have only limited permissions to access another cluster's correct set of Kube objects.
To generate the base64-encoded kubeconfig file, run the following command:
./configureUiPathAS.sh kubeconfig get --multisite./configureUiPathAS.sh kubeconfig get --multisite
Parameter
--multisiteGenerates the kubeconfig file with limited permissions.
Updating the kubeconfig file and linking two Automation Suite clusters
To update the kubeconfig file of another cluster and link both of them, run the following command:
./configureUiPathAS.sh kubeconfig set --secret "fgad8GDH9dbks" --multisite./configureUiPathAS.sh kubeconfig set --secret "fgad8GDH9dbks" --multisite
Parameter
--secretAccepts the base64-encoded kubeconfig file.
--multisiteLinks the two clusters.
Removing the kubeconfig file and delinking two Automation Suite clusters
To remove the kubeconfig file of another cluster and de-link two Automation Suite clusters, run the following command:
./configureUiPathAS.sh kubeconfig unset --multisite./configureUiPathAS.sh kubeconfig unset --multisite
Parameter
--multisite
De-links two Automation Suite clusters.
