- Overview
- Requirements
- Deployment templates
- Manual: Preparing the installation- Manual: Preparing the installation
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Kerberos authentication configuration
- Monitoring configuration
- Cluster administration- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating to an external OCI-compliant registry
- Redirecting traffic for the unsupported services to the primary cluster
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade- Step 1: Moving the Identity organization data from standalone to Automation Suite
- Step 8: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Product-specific configuration- Using the Orchestrator Configurator Tool
- Orchestrator appSettings
- Configuring appSettings
- Troubleshooting- How to troubleshoot services during installation
- How to clear Redis data
- How to enable Istio logging
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- How to forward application logs to Splunk
- How to clean up unused Docker images from registry pods
- Test Automation SQL connection string is ignored
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Longhorn REST API endpoint upgrade/reinstall error
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- After Disaster Recovery Dapr is not working properly for Process Mining
- Configuring Dapr with Redis in cluster mode
- Exploring Logs
- Exploring summarized telemetry
Some Automation Suite products are not supported in Disaster Recovery - Active/Passive and Active/Active. You can install these products while installing the primary cluster only. For details, see Disaster recovery - Active/Passive and Active/Active.
cluster_config.json parameters:
                  For Active/Passive deployments only: configure the parameters for in-cluster High Availability Add-on. For details, see In-cluster High Availability Add-on configuration.
                  For Active/Active deployments only: configure the parameters for external High Availability Add-on. For details, see External High Availability Add-on configuration.
                  For both Active/Active and Active/Passive deployments: configure the parameters listed in the following table.
| Parameter | Description |
| fqdn | It represents the FQDN that, at the time of installation, points to the load balancer of the primary cluster. |
 | Provide the FQDN of the load balancer of the cluster. It is a mandatory value. |
 | It indicates that Automation Suite must be configured to work multi-site. It must be set to  true. |
 | It indicates that this cluster is a primary cluster and must be set to  true. It defaults tofalseto denote the secondary cluster. |
 | It indicates the base64-encoded kubeconfig file of another cluster. While installing the primary Automation Suite cluster, this value is unavailable and can be left as is. However, you must provide the value when rebuilding the primary automation suite later during recovery. |
 | Provide the address where all the node joining requests must be made. This is usually the same as the  cluster_fqdnvalue (the FQDN of the load balancer). |
