- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Kerberos authentication configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Redirecting traffic for the unsupported services to the primary cluster
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Using the Orchestrator Configurator Tool
- Orchestrator appSettings
- Configuring appSettings
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- How to forward application logs to Splunk
- How to clean up unused Docker images from registry pods
- Test Automation SQL connection string is ignored
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Longhorn REST API endpoint upgrade/reinstall error
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- After Disaster Recovery Dapr is not working properly for Process Mining
- Configuring Dapr with Redis in cluster mode
- Exploring Logs
- Exploring summarized telemetry
To provision enough resources for monitoring (see Using the monitoring stack), you should consider the number of vCPUs in the cluster and the amount of desired metric retention. Details on how to set the following monitoring resource configurations are provided next.
The following table describes the monitoring field details:
Parameter |
Description |
In days. This is the amount of days that metrics will be retained for the purpose of visualization in Grafana and manual querying via the Prometheus console. Default value is
7.
In GB. Amount of storage space to reserve per Prometheus replica. A good rule of thumb is to set this value to:
Example: If you set
prometheus_retention to 14 days, and your cluster has 80 cores spread across 5 machines, this becomes:
Default value is
45 and should not be set lower.
If Prometheus starts to run out of storage space, an alert will be triggered with specific remediation instructions. See here. |
In MB. Amount of memory to limit each Prometheus replica to. A good rule of thumb is to set this value to:
Example: If you've set
Default value is
3200 for the single-node evaluation mode, and 6000 for the multi-node HA-ready production mode, and should not be set lower.
If Prometheus starts to run out of memory, an alert will be triggered with specific remediation instructions. See here. |
Example
"monitoring": {
"prometheus_retention": 14,
"prometheus_memory_limit": 16000,
"prometheus_storage_size": 104
}"monitoring": {
