- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Kerberos authentication configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating to an external OCI-compliant registry
- Redirecting traffic for the unsupported services to the primary cluster
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Using the Orchestrator Configurator Tool
- Orchestrator appSettings
- Configuring appSettings
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- How to forward application logs to Splunk
- How to clean up unused Docker images from registry pods
- Test Automation SQL connection string is ignored
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Longhorn REST API endpoint upgrade/reinstall error
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- After Disaster Recovery Dapr is not working properly for Process Mining
- Configuring Dapr with Redis in cluster mode
- Exploring Logs
- Exploring summarized telemetry
The Automation Suite in-place upgrade process allows you to move to a new Automation Suite version while keeping your settings and data intact on the same hardware.
In the in-place upgrade process, you first upgrade Kubernetes and other infrastructure components, and then upgrade the shared components and UiPath® product services.
In case of hard failure beyond recovery during the upgrade process, you need to roll back to the previous version using the backup and restore capability.
- You must meet the hardware and software requirements for the new Automation Suite version. If AI Center is enabled, make sure you meet the CUDA requirements.
- Determine the supported versions for each upgrade scenario by checking the upgrade path matrix.
- Download the required installer and bundle files.
- If you use an in-cluster object store, you must have your cluster object store directly attached to the nodes' disk using Ceph on raw devices available in 2022.4.7, 2022.10, and 2023.4. For details, see Migrating objectstore from persistent volume to raw disks.
- If you plan to upgrade from Automation Suite 2022.10 or earlier, and Process Mining is enabled, you must migrate process apps to the new process graph layout before starting the upgrade.
- Since Longhorn is no longer available in Automation Suite versions starting with 2023.10, when performing an upgrade from versions previous to 2023.10, you must perform additional steps to migrate the Longhorn volumes and uninstall Longhorn.
- An additional disk is required to execute the AI Center training pipeline. Make sure that all the AI Center training pipelines are completed before the upgrade.
- Make sure you meet the CPU core requirements. To check the required number of CPU cores, run the following command:
(alloc=0;for node in $(kubectl get nodes -o custom-columns=NAME:.metadata.name,TAINTS:.spec.taints --no-headers | grep -vE "task.mining|serverless.robot|gpu" | awk -F ' ' '{print $1}'); do alloc=$((alloc + $(echo $(echo $(echo $(kubectl describe node $node | grep "Allocated resources" -A 8 |grep "%" | grep cpu | awk -F ' ' '{print $2}' | tr -d m)*1.2 | bc)*1.2 | bc)/1 | bc) + 600)) done echo "Required CPU cores $(echo "$(echo $alloc+999 | bc)/1000" | bc) for upgrade")(alloc=0;for node in $(kubectl get nodes -o custom-columns=NAME:.metadata.name,TAINTS:.spec.taints --no-headers | grep -vE "task.mining|serverless.robot|gpu" | awk -F ' ' '{print $1}'); do alloc=$((alloc + $(echo $(echo $(echo $(kubectl describe node $node | grep "Allocated resources" -A 8 |grep "%" | grep cpu | awk -F ' ' '{print $2}' | tr -d m)*1.2 | bc)*1.2 | bc)/1 | bc) + 600)) done echo "Required CPU cores $(echo "$(echo $alloc+999 | bc)/1000" | bc) for upgrade")
Upgrade process steps |
1. |
Prepare the upgrade:
2. |
Execute the upgrade:
3. |
Note:
Not all post-upgrade steps are mandatory. Based on your upgrade scenario, you must take specific steps. Post-upgrade steps:
