- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Kerberos authentication configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Redirecting traffic for the unsupported services to the primary cluster
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 8: Migrating standalone Test Manager
- Upgrading Automation Suite
- Executing the upgrade
- Using the Orchestrator Configurator Tool
- Orchestrator appSettings
- Configuring appSettings
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- How to forward application logs to Splunk
- How to clean up unused Docker images from registry pods
- Test Automation SQL connection string is ignored
- DNS settings not honored by CoreDNS
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Longhorn REST API endpoint upgrade/reinstall error
- Service upgrade fails during pre-service script execution
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Failure to add agent nodes in offline environments
- Accessing FQDN returns RBAC: access denied error
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- After Disaster Recovery Dapr is not working properly for Process Mining
- Configuring Dapr with Redis in cluster mode
- Exploring Logs
Add a dedicated agent node for Task Mining, including hardware requirements and AI Center dependency setup in Automation Suite.
Hardware requirements
Before starting the Task Mining installation, make sure to check the Hardware requirements. Task Mining has a dependency on AI Center; therefore, to use Task Mining, you must also install AI Center.
After completing the Automation Suite installation, take the following steps to set up Task Mining.
Enabling Task Mining on the cluster
You can skip this step if you have already enabled Task Mining in the configuration during the main installation. If not, you must enable AI Center and Task Mining by editing the configuration and re-running the installation.
You must enable aicenter and task_mining in the cluster_config.json file when applying the advanced configuration, as shown in the following sample:
"aicenter": {
"enabled": Boolean
"task_mining": {
"enabled": Boolean
"aicenter": {
"enabled": Boolean
"task_mining": {
"enabled": Boolean
Configuring a dedicated node for Task Mining
To add a new Task Mining node to the cluster, take the following steps:
Configure the disks. Make sure to also configure the AI Center disk on the Task Mining node.
Download the installation packages and get them on the Task Mining machine.
Copy the
cluster_config.jsonfile from an existing machine to the new one. -
Optional. If your installation is offline, and you do not have an external registry, you must configure a temporary docker registry.
Validate the prerequisites for the installation.
To add a new node, run the following commands:
- To navigate to the installer folder, run the following commands. Make sure to replace
<version>with the actual installer version.chmod -R 755 /opt/UiPathAutomationSuite cd /opt/UiPathAutomationSuite/<version>/installerchmod -R 755 /opt/UiPathAutomationSuite cd /opt/UiPathAutomationSuite/<version>/installer - To add a new Task Mining node, run the following commands:
./install-uipath.sh -i ./cluster_config.json -o ./output.json -k -j task-mining --accept-license-agreement./install-uipath.sh -i ./cluster_config.json -o ./output.json -k -j task-mining --accept-license-agreement
Enable kubectl. To set the kubectl context on the Task Mining machine, run the following command:
sudo su - export KUBECONFIG=/var/lib/rancher/rke2/agent/kubelet.kubeconfig export PATH=$PATH:/var/lib/rancher/rke2/bin kubectl get nodessudo su - export KUBECONFIG=/var/lib/rancher/rke2/agent/kubelet.kubeconfig export PATH=$PATH:/var/lib/rancher/rke2/bin kubectl get nodesYou should see the node and its corresponding name. You need the name of the Task Mining node for the next step.
Check if the Task Mining node is configured by running the following command. Make sure to update
<node name>with the name of the Task Mining node.kubectl describe node <node name> | grep -i "taints"kubectl describe node <node name> | grep -i "taints"The command should return the following output:
At this point, you have successfully completed the Task Mining installation. Sign in to the Automation Suite Portal and enable Task Mining in the tenant management UX under the Admin section.
Configuring email
You must configure system email notifications as Task Mining relies on the Automation Suite notification system to send emails.
Starting a Task Mining project
For instructions on creating a Task Mining project, see the Task Mining documentation.
Configuring the Task Mining ML Model in AI Center
Before proceeding with the following steps, you must follow the instructions in Uploading ML Packages.
After uploading the ML package, take the following steps:
Access the AI Center homepage for your tenant, and select Create Project. This project can be named anything you want, but we recommend matching it to the name of your Task Mining project.
From the project, navigate to the ML Packages page, and then choose Out of the box Packages.
Select the UiPath Task Mining package.
Select TMAnalyzerModel and select Submit.
Note:Please always select the latest version of the model packages.
Name the package, choose the most recent package version, and select Submit to create a machine-learning deployment package.
