- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Kerberos authentication configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Redirecting traffic for the unsupported services to the primary cluster
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Using the Orchestrator Configurator Tool
- Orchestrator appSettings
- Configuring appSettings
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- How to forward application logs to Splunk
- How to clean up unused Docker images from registry pods
- Test Automation SQL connection string is ignored
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Longhorn REST API endpoint upgrade/reinstall error
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- After Disaster Recovery Dapr is not working properly for Process Mining
- Configuring Dapr with Redis in cluster mode
- Exploring Logs
- Exploring summarized telemetry
Last updated Nov 13, 2025
The in-place upgrade timeouts with
Error: cannot execute upgrade plan on agent nodes: context canceled. However, all nodes were upgraded, but the main logs indicate an upgrade timeout.
For example:
The upgrade log for the first node shows a failed upgrade:
[INFO] [2023-10-11T12:51:12+0000]: Running upgrade on all nodes... Error: cannot execute upgrade plan on agent nodes: context canceled [INFO] [2023-10-11T13:51:12+0000]: Node details: [INFO] [2023-10-11T13:51:12+0000]: NAME STATUS ROLES AGE VERSION agent0 Ready <none> 6h44m v1.26.5+rke2r1 server0 Ready control-plane,etcd,master 7h18m v1.26.5+rke2r1 server1 Ready control-plane,etcd,master 7h2m v1.26.5+rke2r1 server2 Ready control-plane,etcd,master 6h53m v1.26.5+rke2r1 [INFO] [2023-10-11T13:51:12+0000]: Refer the log files in /opt/UiPathAutomationSuite/_upgrade/UiPath_Installer/Modules/../upgrade-logs/upgrade-2023.10.0-rc.12 [INFO] [2023-10-11T13:51:16+0000]: Rke upgrade information is available at system-upgrade namespace. Use kubectl command to get the logs and events. [INFO] [2023-10-11T13:51:16+0000]: Logs also present in the corresponding node at /opt/UiPathAutomationSuite/_autoupgrade ^[[0;31m[ERROR][2023-10-11T13:51:16+0000]:^[[0m Upgrade failed. Please fix the errors and try again.[INFO] [2023-10-11T12:51:12+0000]: Running upgrade on all nodes... Error: cannot execute upgrade plan on agent nodes: context canceled [INFO] [2023-10-11T13:51:12+0000]: Node details: [INFO] [2023-10-11T13:51:12+0000]: NAME STATUS ROLES AGE VERSION agent0 Ready <none> 6h44m v1.26.5+rke2r1 server0 Ready control-plane,etcd,master 7h18m v1.26.5+rke2r1 server1 Ready control-plane,etcd,master 7h2m v1.26.5+rke2r1 server2 Ready control-plane,etcd,master 6h53m v1.26.5+rke2r1 [INFO] [2023-10-11T13:51:12+0000]: Refer the log files in /opt/UiPathAutomationSuite/_upgrade/UiPath_Installer/Modules/../upgrade-logs/upgrade-2023.10.0-rc.12 [INFO] [2023-10-11T13:51:16+0000]: Rke upgrade information is available at system-upgrade namespace. Use kubectl command to get the logs and events. [INFO] [2023-10-11T13:51:16+0000]: Logs also present in the corresponding node at /opt/UiPathAutomationSuite/_autoupgrade ^[[0;31m[ERROR][2023-10-11T13:51:16+0000]:^[[0m Upgrade failed. Please fix the errors and try again. -
The upgrade log for the agent node shows a succesful upgrade:
[INFO] [2023-10-12T12:42:53+0000]: Infra installed successfully [INFO] [2023-10-12T12:42:53+0000]: Validate rke2 images update in the upgrade hook [INFO] [2023-10-12T12:42:53+0000]: checking all rke2 pods are up and running in the current node pod/kube-proxy-agent0 condition met [INFO] [2023-10-12T12:42:54+0000]: Uncordoning node in the upgrade hook Checking if node is ready to run kubectl command. Node is ready to accept kubectl command Enable IP Forwarding... Either file /etc/sysctl.conf not present or file is not writable. Enabling ip forward using /proc/sys/net/ipv4/ip_forward... Uncordon agent0 ... label "nodejanitor/skip" not found. node/agent0 not labeled node/agent0 already uncordoned node/agent0 annotated [INFO] [2023-10-12T12:42:54+0000]: Upgrade successfully completed.[INFO] [2023-10-12T12:42:53+0000]: Infra installed successfully [INFO] [2023-10-12T12:42:53+0000]: Validate rke2 images update in the upgrade hook [INFO] [2023-10-12T12:42:53+0000]: checking all rke2 pods are up and running in the current node pod/kube-proxy-agent0 condition met [INFO] [2023-10-12T12:42:54+0000]: Uncordoning node in the upgrade hook Checking if node is ready to run kubectl command. Node is ready to accept kubectl command Enable IP Forwarding... Either file /etc/sysctl.conf not present or file is not writable. Enabling ip forward using /proc/sys/net/ipv4/ip_forward... Uncordon agent0 ... label "nodejanitor/skip" not found. node/agent0 not labeled node/agent0 already uncordoned node/agent0 annotated [INFO] [2023-10-12T12:42:54+0000]: Upgrade successfully completed.
