- Overview
- Requirements
- Root privileges requirements
- High Availability – three availability zones
- Certificate requirements
- Network requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Kerberos authentication configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Redirecting traffic for the unsupported services to the primary cluster
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Using the Orchestrator Configurator Tool
- Orchestrator appSettings
- Configuring appSettings
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- How to forward application logs to Splunk
- How to clean up unused Docker images from registry pods
- Test Automation SQL connection string is ignored
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Longhorn REST API endpoint upgrade/reinstall error
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- After Disaster Recovery Dapr is not working properly for Process Mining
- Configuring Dapr with Redis in cluster mode
- Exploring Logs
- Exploring summarized telemetry
kubernetes and uipath product services, in High Availability (HA) mode.
HA mode requires at least three server nodes deployed in three distinct availability zones.
To ensure HA with three availability zones, the following requirements must be met:
- Three availability zones that are geographically separate but within close proximity;
- Round Trip Time (RTT) among the availability zones must be minimal (<10 ms RTT);
- All availability zones must provide a consistent set of resources with HA and redundancy;
- Single virtual network span across all the availability zones.
High Availability Add-On (HAA) is required for deploying Orchestrator in a three active availability zone topology on Automation Suite.
The architecture of a configuration with HA with three availability zones has the following characteristics:
- All three zones are linked in the same virtual network;
- Each of the zones must host at least one server node so that there are at least three server nodes installed in Automation Suite to maintain the quorum requirement;
- Each of the zones should host additional balanced
number of agent nodes to meet the overall hardware requirements for running
Automation Suite.
Note:
- SQL server must be configured as failover group spanning across two zones to ensure the entire deployment is resilient to the failure of one zone.
- A minimum of three nodes are required for Elasticsearch in any of the two zones, configured in different clusters and synchronized.
- A minimum of two load balancers in any of the two zones, to ensure High Availability at load balancer level.
To ensure both HA and Disaster Recovery, you can employ the deployment model illustrated in the following image. In this example, all three zones are active, and the traffic manager is employed to use a specific algorithm, such as Round Robin or one of its variants to direct traffic to any of the load balancers. Similarly to the traffic manager, the load balancer will direct traffic to any of the availability zones.
