Last updated Nov 6, 2025
Configuring the DNS
The Automation Suite cluster is exposing multiple URLs to access the cluster management tools and the suite core functionality, all based on a common FQDN.
You need to configure the DNS for the common FQDN and the subdomains specific to each tool as shown in the following table.
Application
Domain
Example URL
Automation Suite
fqdn
automationsuite.mycompany.com
Application Lifecycle Management (ALM)
alm.{{fqdn}}
alm.automationsuite.mycompany.com
Monitoring / Observability
monitoring.{{fqdn}}
monitoring.automationsuite.mycompany.com
Object Store
objectstore.{{fqdn}}
objectstore.automationsuite.mycompany.com
Docker Registry
registry.{{fqdn}}
registry.automationsuite.mycompany.com
Insights
insights.{{fqdn}}
insights.automationsuite.mycompany.com
Configuring DNS using public domain registrar
Add an A Record in Advanced DNS or Management section of your domain as shown in the following table:
Type
Host
Value
A Record (or CName)
automationsuite (or a subdomain to access Automation Suite)
  • For A Record: the IP address of the machine
  • For CName: the DNS name associated with the machine
A Record (or CName)
*.automationsuite (or a subdomain to access Automation Suite)
See the following example for the configuration:
Note: If the * wildcard is too generic, add a separate record or rule for the following subdomains: alm, monitoring, objectstore, registry, and insights.
For rest or evaluation deployments: Creating a private DNS zone
As a workaround, you can use a private domain for testing purposes only.
For an example, see Sample Azure infrastructure setup.
