- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
Last updated Nov 6, 2025
This issue occurs when the certificate update step fails internally. You may not able to access Automation Suite or Orchestrator.
Run the following commands from any of the server node:
export KUBECONFIG=/etc/rancher/rke2/rke2.yaml export PATH=$PATH:/var/lib/rancher/rke2/bin kubectl -n uipath rollout restart deploymentsexport KUBECONFIG=/etc/rancher/rke2/rke2.yaml export PATH=$PATH:/var/lib/rancher/rke2/bin kubectl -n uipath rollout restart deployments -
Wait for the previous command to succeed and then run the following command to verify the status of previous command.
deployments=$(kubectl -n uipath get deployment -o name) for i in $deployments; do kubectl -n uipath rollout status "$i" -w --timeout=600s; if [[ "$?" -ne 0 ]]; then echo "$i deployment failed in namespace uipath." fi done echo "All deployments are succeeded in namespace uipath"deployments=$(kubectl -n uipath get deployment -o name) for i in $deployments; do kubectl -n uipath rollout status "$i" -w --timeout=600s; if [[ "$?" -ne 0 ]]; then echo "$i deployment failed in namespace uipath." fi done echo "All deployments are succeeded in namespace uipath"
Once the previous command has finished executing, you should able to access Automation Suite and Orchestrator.
