- Overview
- Requirements
- Installation- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade- Migration options
- Troubleshooting- How to troubleshoot services during installation
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
This step is mandatory for a multi-node HA-ready production deployment or a single-node evaluation deployment with a dedicated Task Mining and/or GPU node.
If you are configuring a single-node evaluation deployment without a dedicated Task Mining and/or GPU node, proceed to Configuring Azure SQL.
If you are using the Azure Internal Load Balancer (LB) for deployments, you can encounter issues with the calls from the backend Virtual Machine (VM) to the LB frontend IP. The issues occur due to source IP and MAC address mismatch of the network packet. This prevents the recipient from working out the correct response path, resulting in the failure of calls from the VM to the LB. For more details, see Azure Load Balancer Components limitations and Backend Traffic Troubleshooting.
If you are installing Task Mining, the dedicated Task Mining should not be added in the node pool.
The Task Mining Analyzer node should not be added in the node pool.
Make sure to repeat these steps for all virtual networks corresponding to each node.
The recommended configuration is to add two backend pools, as follows:
- one backend pool that includes all server nodes (referred to as the Server Pool);
- one backend pool with all server and agent nodes (minus the Task Mining node, and this pool is referred to as the Node Pool in our documentation).
kubeapi-probe, whereas the Node Pool is associated with the https-probe.
                  443, 6443, and 9345.
