- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
Last updated Nov 6, 2025
To clean up snapshots automatically, you must create a cronjob using the following file. To create the cronjob, run
kubectl apply -f snapshot-cleanup.yaml. You can change the schedule parameter accordingly. By default, this cronjob deletes snapshots older than 10 days. You can reduce this period by updating
the days variable.
apiVersion: batch/v1
kind: CronJob
metadata:
annotations:
labels:
job: uipath-snapshot-cleanup
namespace: longhorn-system
spec:
concurrencyPolicy: Forbid
failedJobsHistoryLimit: 1
jobTemplate:
spec:
backoffLimit: 3
template:
metadata:
labels:
spec:
containers:
- command:
- sh
args:
- -ec
url=$(kubectl get svc -n longhorn-system longhorn-backend -o json | jq -r '.spec | (.clusterIP|tostring) + ":" + (.ports[0].port|tostring)')
days=10
[[ -z "$url" ]] && echo "Missing longhorn URL" && exit 1
curl -s --connect-timeout 30 ${url}/v1 >> /dev/null || { echo "Unable to connect to longhorn backend"; exit 1; }
echo "Deleting snapshots older than $days days"
vols=$( (curl -s -X GET ${url}/v1/volumes |jq -r '.data[].name') )
function delete_snapshot() {
local vol=$1
local snap=$2
[[ -z "$vol" || -z "$snap" ]] && echo "Error: delete_snapshot: Empty argument" && return 1
curl -s -X POST ${url}/v1/volumes/${vol}?action=snapshotDelete -d '{"name": "'$snap'"}'
echo "Snapshot=$snap deleted for volume=$vol"
function cleanup_volume() {
local vol=$1
local deleted_snap=0
[[ -z "$vol" ]] && echo "Error: cleanup_volume: Empty argument" && return 1
# fetch list of snapshot
snaps=$( (curl -s -X POST ${url}/v1/volumes/${vol}?action=snapshotList | jq -r '.data[] | select(.usercreated==true) | .name' ) )
for i in ${snaps[@]}; do
if [[ $i == "volume-head" ]]; then
continue
fi
snapTime=$(curl -s -X POST ${url}/v1/volumes/${vol}?action=snapshotGet -d '{"name":"'$i'"}' |jq -r '.created')
currentTime=$(date "+%s")
timeDiff=$(($currentTime - ($(date -d $snapTime "+%s")) / 86400))
if [[ $timeDiff -lt $days ]]; then
echo "Ignoring snapshot $i, since it is older than $timeDiff days"
continue
fi
delete_snapshot $vol $i
deleted_snap=$((deleted_snap+1))
done
if [[ "$deleted_snap" -gt 0 ]]; then
curl -s -X POST ${url}/v1/volumes/${vol}?action=snapshotPurge >> /dev/null
fi
for i in ${vols[@]}; do
cleanup_volume $i
done
exit 0
env:
- name: POD_NAMESPACE
valueFrom:
fieldRef:
apiVersion: v1
fieldPath: metadata.namespace
image: uipath/sf-k8-utils-rhel:0.9
imagePullPolicy: IfNotPresent
resources: {}
terminationMessagePath: /dev/termination-log
terminationMessagePolicy: File
dnsPolicy: ClusterFirst
priorityClassName: system-cluster-critical
restartPolicy: OnFailure
schedulerName: default-scheduler
securityContext: {}
serviceAccount: longhorn-service-account
serviceAccountName: longhorn-service-account
terminationGracePeriodSeconds: 30
tolerations:
- effect: NoSchedule
key: kubernetes.io/hostname
operator: Equal
value: server0
schedule: '0 11 * * *'
successfulJobsHistoryLimit: 1
suspend: falseapiVersion: batch/v1
kind: CronJob
metadata:
annotations:
labels:
spec:
jobTemplate:
spec:
backoffLimit: 3
template:
metadata:
labels:
spec:
containers:
- command:
- sh
args:
- -ec
days=10
local vol=$1
local snap=$2
local vol=$1
continue
fi
continue
fi
done
fi
cleanup_volume $i
done
exit 0
env:
valueFrom:
fieldRef:
apiVersion: v1
resources: {}
securityContext: {}
tolerations:
operator: Equal
value: server0
suspend: false
