Last updated Nov 6, 2025
Sample Azure infrastructure setup
The following table lists the steps you need to take to configure the infrastructure in Azure for both single-node evaluation and multi-node HA-ready production profiles.
Step
Instructions
Single-node evaluation profile
Multi-node HA-ready production profile
Required during installation
Step 1: Configure a VM node
<details>:
Basics; Configure Disks; Networking
Configure the DNS of the VM; Partitioning the disk; Additional networking configuration for multi-node
Configure one node
Configure a minimum of 3 nodes.
  • Follow additional instructions specific to multi-node.
  • Username and password used when creating the VM.
  • FQDN of the first VM.
  • For the single-node evaluation profile, provide this FQDN as the Cluster FQDN.
N/A
Required
  • FQDN of the load balancer.
  • For multi-node, provide this FQDN as the Cluster FQDN.
Required
Required
  • SQL Server FQDN and SQL Server credentials.
You must create an Azure storage account if you opt for external objectstore.
For production deployments:
For test or evaluation deployments:
Required
Required
Step 6: Install Automation Suite
At this point, configuration is complete, and you can install Automation Suite.
