- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
Last updated Nov 6, 2025
After performing an Automation Suite cluster upgrade, some changes are needed to ensure a
new node joins the cluster correctly through scale-out operations. To automate the
changes, we recommend using the
upgrade_wrapper.py script.
Prerequisites
Make sure you meet the following requirements:
- Python 3.8 or newer must be installed on the machine on which you execute the script. For details, see Python documentation.
- Python packages are required for the script. You can install these packages using the following pip command. For details,
see pip documentation.
pip install wget requests boto3pip install wget requests boto3 boto3clients must be able to authenticate to AWS because deployment changes occur through them. You can provide credentials as environment variables or through a default profile using a shared credential file. The user must have the permission to perform the actions described in the Script behavior section.- Make sure to review the
cluster_config.jsonfile and change any boolean values marked as string ("true"/"false") to actual boolean values (true/false). For example:- to enable zone resilience, use
"zone_resilience": true. - to allow the installer to create the databases, use
"sql.create_db": true.
- If you upgrade from Automation Suite 2022.10 to Automation Suite 2023.4 or later, and Orchestrator is enabled on both the
old and new versions, you must set the
orchestrator.block_classic_executionsflag totruein thecluster_config.jsonfile. Using the flag shows that you agree with blocking classic folders executions. Not using the flag causes the upgrade operation to fail. This parameter is not required in new installations.
Script considerations
When running the
upgrade_wrapper.py script, take into consideration the fact that it performs the following operations:
- Downloads in the current folder the dependencies needed;
- Extracts information from the Automation Suite deployment stack;
Creates a new stack containing:
- A new Launch Template for each Auto Scaling Group present in the initial deployment with the changes needed for the new version installation flow;
An IAM policy attached to the IAM role used by the Automation Suite nodes that allows the
DescribeStackResourceoperation on the current stack;Note: The policy is deployed only if a custom IAM role was not provided at deployment time. Otherwise you should grant thecloudformation:DescribeStackResourcepermission on the newly deployed stack to the IAM role used by the Automation Suite nodes.
- Updates the Auto Scaling Group to use the Launch Templates created in the new stack;
- Updates the SSM parameter containing the installer URL (optional, depending on the initial deployment template version);
Overrides the old installer used in the initial deployment with the one used for upgrade on all nodes through an SSM Run Command. This is needed to preserve the functionality of the SSM documents already existent in the initial deployment;
Note: The AMI update SSM document might no longer work after the Launch template update. The IAM role used by the SSM documents should be updated with theec2:CreateLaunchTemplateVersionpermission, andec2:RunInstancespermissions on the newly created Launch Templates. - Cleans up the downloaded files.
