- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
Last updated Nov 6, 2025
| Azure template version | 2022.10.5 |
| Automation Suite version | 2022.10.5 |
What's new
You can now install Automation Suite 2022.10.5 using the Azure deployment template.
| Azure template version | 2022.10.4 |
| Automation Suite version | 2022.10.1 |
Bug fixes
Certain
yum install commands failed due to external repository certificate issues. The problem no longer occurs.
| Azure template version | 2022.10.3 |
Bug Fixes
We have fixed an issue causing Automation Suite upgrades to fail if you did not update the
cluster_config.json file.
| Azure template version | 2022.10.2 |
What’s New
The Azure deployment template now provides support for upgrades to newer Automation Suite versions.
After performing an Automation Suite upgrade, the Azure template deployment requires some adjustments to ensure that new nodes
join the cluster correctly. To automate these changes, we recommend using the
upgradeUiPathAS.sh script. For more details and instructions, see Completing an upgrade.
Improvements
The installation script now offers the option to download the
cluster_config.json file from the Key Vault.
| Azure template version | 2022.10.1 |
What’s New
You can now install Automation Suite 2022.10.1 using the Azure deployment template.
Improvements
We have improved the restore logic.
| Azure template version | 2022.10.0 |
| Automation Suite version | 2022.10.0 |
What’s New
- You can now install new services using the Azure deployment template. Process Mining and Automation Suite Robots are the latest additions to the suite.
- You can now install strictly the products you are interested in using the Azure deployment template as we have deprecated the Basic product selection and made Orchestrator optional.
- You can now connect AI Center to an external Orchestrator. To do that, you must explicitly opt for this functionality and provide certificates for Orchestrator and Identity.
- We have introduced a new tool guiding you through the steps you need to take to complete the Automation Suite installation as well as common post-installation operations. It is called Cluster Administration, and it provides useful instructions on certificate configuration, Kerberos authentication setup, node administration, database maintenance, cluster monitoring, and more. For details on how to access the tool, see Post-deployment steps.
- The Azure template now defaults to RHEL 8.6.
- We have added
Standard_D8s_v3andStandard_F8s_v2to the list of possible VM instance types for server and agent instance types. - We have introduced a paradigm change in terms of storage: when using the Azure deployment template, your data is stored externally.
- You can now perform backup and restore cluster operations through Automation Account runbooks. For more details, see Azure VM lifecycle operations.
