- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
Last updated Nov 6, 2025
The EFK (Elasticsearch, Fluentd, Kibana) stack is a centralized logging solution that allows you to search, analyze and visualize log data. Fluentd collects and sends the logs to Elasticsearch, Kibana retrieves the logs and lets you visualize and analyze the data.
Automation Suite supports Elasticsearch version 7.x.
If your Elasticsearch instance requires credentials, create a secret with its password in the cluster.
kubectl -n cattle-logging-system create secret generic elastic-user --from-literal=password=<password>kubectl -n cattle-logging-system create secret generic elastic-user --from-literal=password=<password>Run the following command to ClusterOutput to Elasticsearch. Replace the following attributes with the ones of your Elasticsearch configuration:
<elasticsearch host>- the network host of your Elasticsearch instance;<elasticsearch port>- the Elasticsearch port for client communication;<secret key>- the secret with the Elasticsearch password;timekeyvalue inelasticsearch.buffer- the output frequency i.e. how often you want to push logs;-
elasticsearch.scheme- the URL scheme. Valid values are:httporhttps.kubectl -n cattle-logging-system apply -f - <<"EOF" apiVersion: logging.banzaicloud.io/v1beta1 kind: ClusterOutput metadata: name: es-output spec: elasticsearch: host: <elasticsearch host> port: <elasticsearch port> scheme: <http or https> ssl_verify: false ssl_version: TLSv1_2 user: elastic password: valueFrom: secretKeyRef: name: elastic-user key: <secret key> buffer: timekey: 10m timekey_wait: 30s timekey_use_utc: true EOFkubectl -n cattle-logging-system apply -f - <<"EOF" apiVersion: logging.banzaicloud.io/v1beta1 kind: ClusterOutput metadata: name: es-output spec: elasticsearch: host: <elasticsearch host> port: <elasticsearch port> scheme: <http or https> ssl_verify: false ssl_version: TLSv1_2 user: elastic password: valueFrom: secretKeyRef: name: elastic-user key: <secret key> buffer: timekey: 10m timekey_wait: 30s timekey_use_utc: true EOF
Run the following command to ClusterFlow in FluendD:
kind: ClusterFlow
metadata:
spec:
filters:
- tag_normaliser:
format: ${namespace_name}/${pod_name}.${container_name}
globalOutputRefs:
- es-output
match:
- select:
container_names:
- istio-proxy
namespaces:
- istio-system
- exclude:
container_names:
- istio-proxy
- istio-init
- aicenter-hit-count-update
- exclude:
namespaces:
- fleet-system
- cattle-gatekeeper-system
- default
- exclude:
labels:
app: csi-snapshotter
- exclude:
labels:
longhorn.io/job-task: backup
- exclude:
labels:
app: csi-resizer
- select: {}
kind: ClusterFlow
metadata:
spec:
filters:
- tag_normaliser:
globalOutputRefs:
- es-output
match:
- select:
container_names:
- istio-proxy
namespaces:
- istio-system
- exclude:
container_names:
- istio-proxy
- istio-init
- exclude:
namespaces:
- fleet-system
- default
- exclude:
labels:
- exclude:
labels:
- exclude:
labels:
app: csi-resizer
- select: {}
EOFLogs from the cluster are collected and logged to the
ClusterOutput.
