- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
You must meet the hardware and software prerequisites before proceeding with the installation. See Hardware and software requirements.
You can use a dedicated script to validate the installation prerequisites and infrastructure readiness. See Validating the prerequisites.
For a smooth installation experience, make sure to follow our best practices. See .
The installation process has the following general steps:
Step |
Description |
Step 1: Download the installation packages |
Perform this step from a Linux or Windows machine with access to the internet and to the offline machines where you plan to deploy Automation Suite. While the installation packages finish downloading, you can continue to some of the next steps. |
Step 2: Configure the installation |
The interactive installer gathers inputs for most common installation options and generates a configuration that you can use during installation. The interactive installer offers a default experience with a limited number of configuration options. To customize the installed products, set up separate SQL servers for specific products, and more, edit the configuration file. |
Step 3: Run the installation |
Run the installation.Once the installation is complete, you can start using the cluster. |
Step 4: Complete the installation |
You have completed the installation successfully and can move to post-installation steps. You can now access the newly created cluster and suite, update certificates, resize the PVC, and more. |
RHEL kernel version kernel-4.18.0-477.10.1.el8_8 is affected by an issue that interrupts the installation or management of the Automation Suite cluster. Make sure that none of the Automation Suite nodes uses this kernel version either pre- or post-installation. You can update the kernel version by running the following command:
dnf install -y kernel kernel-tools kernel-tools-libsdnf install -y kernel kernel-tools kernel-tools-libsStep 1.1: Downloading the installation packages
You must perform this step on a Linux or Windows machine with access to the internet and to the machine in the offline environment where you plan to install Automation Suite.
The commands on this page are for a RHEL-based OS. For Windows or other OSes, adjust for equivalent commands specific to those environments.
ON THE SEPARATE MACHINE WITH INTERNET ACCESS
This section explains how to get the required files to start the installation process.
Step 1.2: Getting all downloaded files on the machine
Make sure to take the following steps:
- Check that all files finished downloaded on the machine with internet access;
- Create the target folder on the machine;
- Copy the files from the online machine to the target machine.
ON THE MAIN MACHINE OF THE CLUSTER
Create the installation folder by running the following command:
sudo su -
mkdir -p /opt/UiPathAutomationSuite/
chmod -R 755 /opt/UiPathAutomationSuite
mkdir -p /uipath/tmp
chmod -R 777 /uipath/tmpsudo su -
chmod -R 777 /uipath/tmpmkdir -p /opt/UiPathAutomationSuite/ is not required if you use the configureUiPathDisks.sh script.
Copy the files to one of the nodes:
Step 2.1: Default configuration
Running the interactive wizard in single-node offline mode
Run the interactive installer to configure the installation options. The tool gathers inputs for the most common installation options and generates a configuration file. HAA is not supported in single-node evaluation mode.
To install Automation Suite, take the following steps:
Step 2.2: (Optional) Advanced configuration
This step is optional.
cluster_config.json file in the UiPathAutomationSuite folder. You can use this file to enable additional products, disable any of the default products, configure your SQL DBs
and their respective connection strings, and certificates. You can also enable proxy settings if you use a proxy for internet
connection.
For single-node evaluation installation, note that you cannot enable High Availability.
For advanced configuration, see Advanced installation experience.
You can re-run the wizard after the complete installation.
Make sure you copied the downloaded files on the main offline machine, where you performed the configuration, in the install folder created by the install wizard.
Accepting the license agreement
Before running the installation, make sure to read the License Agreement.
To accept the license agreement, choose one of the following methods:
- Option 1 (Environment Variable): Set the
LICENSE_AGREEMENTenvironment variable to accept by executing the following command:export LICENSE_AGREEMENT=accept - Option 2 (Inline parameter): Alternatively, append
--accept-license-agreementto every execution ofinstall-uipath.sh.
Running the installation
Run the installation commands to execute the offline bundle (estimated duration: 2h30min - 3h30min):
./install-uipath.sh -i ./cluster_config.json -o ./output.json -a --offline-bundle /uipath/tmp/sf.tar.gz --offline-tmp-folder /uipath/tmp --install-offline-prereqs --accept-license-agreement./install-uipath.sh -i ./cluster_config.json -o ./output.json -a --offline-bundle /uipath/tmp/sf.tar.gz --offline-tmp-folder /uipath/tmp --install-offline-prereqs --accept-license-agreement./install-uipath.sh -h --accept-license-agreement.
Loading the optional bundles
To load the optional Document Understanding bundles, execute the following commands:
./configureUiPathAS.sh registry upload --optional-offline-bundle "/uipath/tmp/du-ondemand.tar.gz" --offline-tmp-folder "/uipath/tmp"./configureUiPathAS.sh registry upload --optional-offline-bundle "/uipath/tmp/du-ondemand.tar.gz" --offline-tmp-folder "/uipath/tmp"./configureUiPathAS.sh registry upload --optional-offline-bundle "/uipath/tmp/cv-ondemand.tar.gz" --offline-tmp-folder "/uipath/tmp"./configureUiPathAS.sh registry upload --optional-offline-bundle "/uipath/tmp/cv-ondemand.tar.gz" --offline-tmp-folder "/uipath/tmp"This document focuses on -a command argument as this caters to need of installing all the required components.
Installing Task Mining
If you install Task Mining in single-node evaluation mode, you need to run an additional set of steps. Follow the Task Mining installation guide to complete the steps for Task Mining.
Updating Certificates
The installation process generates self-signed certificates on your behalf. However, the Azure deployment template also gives you the option to provide a CA-issued server certificate at installation time instead of using an auto-generated self-signed certificate.
Self-signed certificates will expire in 90 days, and you must replace them with certificates signed by a trusted CA as soon as installation completes. If you do not update the certificates, the installation will stop working after 90 days.
For instructions, see Managing certificates.
Accessing Automation Suite
To access the newly created cluster and suite, see Accessing Automation Suite.Completing an AI Center installation
If AI Center requires an external Orchestrator, run the following command to complete the installation:
./configureUiPathAS.sh aicenter configure --installation-token <identity token>./configureUiPathAS.sh aicenter configure --installation-token <identity token>Resizing PVC
To resize the PVC, see Resizing PVC.
- Overview
- Step 1: Downloading the installation packages and getting the files on the machine
- Step 1.1: Downloading the installation packages
- Step 1.2: Getting all downloaded files on the machine
- Step 2: Configuring the installation
- Step 2.1: Default configuration
- Step 2.2: (Optional) Advanced configuration
- Step 3: Running the installation
- Accepting the license agreement
- Running the installation
- Loading the optional bundles
- Installing Task Mining
- Step 4: Completing the Installation
- Updating Certificates
- Accessing Automation Suite
- Completing an AI Center installation
- Resizing PVC
