- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
Last updated Nov 6, 2025
When uploading data, the following error message can occur:
You logged in to Automation Suite using Kerberos and you are not using Kerberos for SQL authentication. In this case, when uploading data the SQL connection for the Process Mining data warehouse is handled this as a Kerberos setup for authentication.
In ArgoCD go to the App details of your Airflow app, locate the SYNC POLICY section on the SUMMARY tab, and select DISABLE AUTO-SYNC.This will prevent the
enableSqlIntegratedAuthto be set back totrueafter you changed it. -
Go to the PARAMETERS tab. Edit the flag
enableSqlIntegratedAuthtofalseand select Save.
