Last updated Nov 13, 2025
Process Mining ingestion failed when logged in using Kerberos
When uploading data, the following error message can occur:
docs image
Possible cause
You logged in to Automation Suite using Kerberos and you are not using Kerberos for SQL authentication. In this case, when uploading data the SQL connection for the Process Mining data warehouse is handled this as a Kerberos setup for authentication.
Possible solution
  1. In ArgoCD go to the App details of your Airflow app, locate the SYNC POLICY section on the SUMMARY tab, and select DISABLE AUTO-SYNC.
    docs image
    This will prevent the enableSqlIntegratedAuth to be set back to true after you changed it.
  2. Go to the PARAMETERS tab. Edit the flag enableSqlIntegratedAuth to false and select Save.
    docs image
  • Possible cause
  • Possible solution
