- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- AI Center-specific configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
- Exploring summarized telemetry
Last updated Nov 13, 2025
documentunderstanding is a property in the Automation Suite's configuration
file, cluster_config.json. It contains
configurable values that control the behavior of the Document Understanding service. The
installer generates the default values. Additional changes can be made to further
configure the Document Understanding service. If you need to change any settings related
to Document Understanding, the documentunderstanding section in cluster_config.json can be edited and the
installer can be re-run.
Alternatively, the same changes can be made in the UiPath® app in ArgoCD.
"documentunderstanding": {
"enabled": true,
"sql_connection_str": "",
"datamanager": {
"sql_connection_str": "String",
"pyodbc_sql_connection_str": "String"
"extendedOcr": {
"enabled": null,
"license": "license obtained"
"modernProjects": {
"enabled": true
}"documentunderstanding": {
"enabled": true,
"datamanager": {
"extendedOcr": {
"enabled": null,
"modernProjects": {
"enabled": true
}Note:
The data manager SQL connection string is optional only if you want to overwrite the default database with your own.
datamanager.sql_connection_str
- Connection string for datamanager
- Required: False.
- This property is generated and populated by the installer, you do not need to set it unless you want to override the default connection string. For more details about connecting to SQL please refer to the Database configuration page.
datamanager.pyodbc_sql_connection_str
- Required: False.
modernProjects
- Setting for Document Understanding modern projects.
- Required: True
- Default: True
extendedOcr
- Setting this to true enables UiPath Extended Languages OCR.
- Required: False
- License: value depends on if a license is obtained or not
For more information on how to obtain a license for UiPath Extended Language OCR and enable it, check the Enabling or disabling Extended Languages OCR page.
