Last updated Apr 24, 2026
Azure Deployment Template
Important:
This deployment template is currently deprecated and is planned for removal in October 2025. As an alternative, consider using Automation Suite on EKS/AKS or reach out to support.
StepInstructions
Azure deployment architectureArchitecture diagram
Components
Step 1: Preparing the Azure deploymentAzure subscription
Quotas
VM family region availability
DNS
Step 2: Deploying Automation Suite to AzureDeploying Automation Suite to Azure
Step 3: Post-deployment stepsValidating the installation
Updating certificates
Enabling FIPS 140-2
Accessing deployment outputs
Accessing cluster VMs
DNS requirements
Accessing the Cluster Administration portal
Accessing Automation Suite general interface
Accessing host administration
Accessing ArgoCD
Accessing Rancher
Scaling your cluster
Completing an upgrade
Azure VM lifecycle operations
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
