Last updated Nov 13, 2025
Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
After upgrading to Automation Suite 2024.10.0, you can no longer access Automation Hub due to database schema discrepancies. We fixed the issue in Automation Suite 2024.10.1.
Solution
To address the problem, you must run the following SQL script on the AutomationSuite_Automation_Hub database:
-- IMPORTANT:
-- This script should be executed in the AutomationSuite_Automation_Hub database.
-- Purpose:
-- This script resolves potential issues encountered during the upgrade to version 2024.10.0 of Automation Hub.
-- Please replace placeholders with actual data before running the script.
-- Assumptions:
-- The customer has an existing Automation Hub instance running a version prior to 2024.10.0.
-- Variables:
-- @AccountName: Logical name of the Automation Suite organization. Replace '<USER_INPUT>' with the actual name.
-- @TenantName: Logical name of the Automation Suite tenant. Replace '<USER_INPUT>' with the actual name.
-- Note:
-- The script will terminate if any errors occur and will provide error details for debugging.
SET XACT_ABORT ON;
-- Replace placeholders with actual values
DECLARE @AccountName NVARCHAR(255) = '<USER_INPUT>';
DECLARE @TenantName NVARCHAR(255) = '<USER_INPUT>';
-- DO NOT EDIT ANYTHING AFTER THIS POINT --
BEGIN TRY
    BEGIN TRANSACTION;
    -- Validate placeholders
    IF @AccountName = '<USER_INPUT>' OR
       @TenantName = '<USER_INPUT>'
    BEGIN
        RAISERROR('Placeholders were not replaced with actual values. Please update the script and retry.', 16, 1);
        RETURN;
    END;
    -- Declare variables for tenant information
    DECLARE @TenantUUID NVARCHAR(255);
    DECLARE @TsTablePrefix NVARCHAR(255);
    -- Retrieve tenant_uuid from the cloud_tenants table based on TenantName and AccountName
    DECLARE @sql NVARCHAR(MAX);
    DECLARE @params NVARCHAR(MAX);
    SET @sql = N'SELECT @TenantUUID = tenant_uuid
                  FROM ah.cloud_tenants
                  WHERE cloud_TenantName = @TenantName
                    AND cloud_AccountName = @AccountName;';
    SET @params = N'@TenantName NVARCHAR(255), @AccountName NVARCHAR(255), @TenantUUID NVARCHAR(255) OUTPUT';
    EXEC sp_executesql @sql,
                       @params,
                       @TenantName = @TenantName,
                       @AccountName = @AccountName,
                       @TenantUUID = @TenantUUID OUTPUT;
    -- Abort if tenant_uuid is not found
    IF @TenantUUID IS NULL
    BEGIN
        RAISERROR('No tenant found for the provided TenantName and AccountName. Script execution aborted.', 16, 1);
        RETURN;
    END;
    -- Retrieve tenant_db_table_prefix from tenants table using tenant_uuid
    SET @sql = N'SELECT @TsTablePrefix = tenant_db_table_prefix
                  FROM ah.tenants
                  WHERE tenant_uuid = @TenantUUID;';
    SET @params = N'@TenantUUID NVARCHAR(255), @TsTablePrefix NVARCHAR(255) OUTPUT';
                       @params,
                       @TenantUUID = @TenantUUID,
                       @TsTablePrefix = @TsTablePrefix OUTPUT;
    -- Abort if tenant_db_table_prefix is not found
    IF @TsTablePrefix IS NULL
    BEGIN
        RAISERROR('No tenant found in the tenants table for the provided tenant_uuid. Script execution aborted.', 16, 1);
        RETURN;
    END;
    -- Drop the default constraint for assignment_days column
    DECLARE @ConstraintName NVARCHAR(200);
    SELECT @ConstraintName = dc.name
    FROM sys.default_constraints dc
        INNER JOIN sys.columns c
            ON dc.parent_object_id = c.object_id
           AND dc.parent_column_id = c.column_id
    WHERE c.object_id = OBJECT_ID(@TsTablePrefix + 'process_cost_benefit_one_time_costs_estimates')
        AND c.name = 'assignment_days';
    IF @ConstraintName IS NOT NULL
    BEGIN
        EXEC('ALTER TABLE ' + @TsTablePrefix + 'process_cost_benefit_one_time_costs_estimates DROP CONSTRAINT [' + @ConstraintName + ']');
    END;
    -- Recreate the default constraint for assignment_days
    DECLARE @UniqueConstraintName NVARCHAR(255) = '[' + @TsTablePrefix + 'DF_assignment_days]';
    BEGIN
        EXEC('ALTER TABLE ' + @TsTablePrefix + 'process_cost_benefit_one_time_costs_estimates ADD CONSTRAINT ' + @UniqueConstraintName + ' DEFAULT 0.00 FOR assignment_days');
    END
    -- Drop the index on the assignment_days column
    IF EXISTS (SELECT 1
               FROM sys.indexes
               WHERE name = 'assignment_days'
				 AND object_id = OBJECT_ID(@TsTablePrefix + 'process_cost_benefit_one_time_costs_estimates')
    BEGIN
        EXEC('DROP INDEX assignment_days ON ' + @TsTablePrefix + 'process_cost_benefit_one_time_costs_estimates');
    END;
    -- Alter the assignment_days column
    EXEC('ALTER TABLE ' + @TsTablePrefix + 'process_cost_benefit_one_time_costs_estimates ALTER COLUMN assignment_days NUMERIC(15, 2) NOT NULL');
    -- Recreate the index on assignment_days
    EXEC('CREATE NONCLUSTERED INDEX assignment_days ON ' + @TsTablePrefix + 'process_cost_benefit_one_time_costs_estimates (assignment_days ASC)');
    -- Insert a record into the migrations table
    EXEC('INSERT INTO ' + @TsTablePrefix + 'migrations (name, run_on) VALUES (''tenants/20230925145641-edit-cba-one-time-costs-estimates-table-column'', CURRENT_TIMESTAMP)');
    -- Commit the transaction
    COMMIT TRANSACTION;
    PRINT 'Script executed successfully.';
END TRY
BEGIN CATCH
    IF @@TRANCOUNT > 0
        ROLLBACK TRANSACTION;
    -- Output error details
    PRINT 'Error occurred during script execution:';
    PRINT 'Error Number: ' + CAST(ERROR_NUMBER() AS VARCHAR(10));
    PRINT 'Error Severity: ' + CAST(ERROR_SEVERITY() AS VARCHAR(10));
    PRINT 'Error State: ' + CAST(ERROR_STATE() AS VARCHAR(10));
    PRINT 'Error Procedure: ' + ISNULL(ERROR_PROCEDURE(), '');
    PRINT 'Error Line: ' + CAST(ERROR_LINE() AS VARCHAR(10));
    PRINT 'Error Message: ' + ERROR_MESSAGE();
END CATCH;-- IMPORTANT:
-- Purpose:
-- Assumptions:
-- Variables:
-- Note:
SET XACT_ABORT ON;
BEGIN TRY
    BEGIN TRANSACTION;
    BEGIN
        RETURN;
    END;
                       @params,
    BEGIN
        RETURN;
    END;
                  FROM ah.tenants
                       @params,
    BEGIN
        RETURN;
    END;
    BEGIN
    END;
    BEGIN
    END
    IF EXISTS (SELECT 1
               FROM sys.indexes
    BEGIN
    END;
    COMMIT TRANSACTION;
END TRY
BEGIN CATCH
    IF @@TRANCOUNT > 0
END CATCH;
  • Description
  • Solution
