- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- AI Center-specific configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
- Exploring summarized telemetry
This page documents the AWS parameters you need to configure when deploying Automation Suite to AWS.
Parameter label (name) |
Default value |
Description |
Deploy to an existing VPC |
Choose
true to deploy Automation Suite in an
existing VPC.
Default value |
Description |
VPC CIDR |
VPC CIDR block. Example:
x.y.0.0/16, x.y.z.0/24.
VPC ID |
ID of the existing VPC. |
Public subnet IDs |
List of public subnet IDs to deploy the internet-facing Load Balancer and the Bastion host. |
Private Subnet IDs |
List of private subnet IDs. |
Default value |
Description |
Availability Zones |
Choose up to three Availability Zones to use for the VPC subnets. |
Default value |
Description |
Number of Availability Zones |
Choose the number of Availability Zones to use in the VPC. This must match the number of zones selected in the Availability Zones parameter. |
Deploy Bastion host |
Deploy a Bastion host inside the public subnet. |
CIDR for bastion's ingress for SSH traffic |
Ingress Security Group CIDR (for SSH). Configure this parameter only if you have set the Deploy Bastion host parameter to
true. Set to x.x.x.x/32 to allow one specific IP address access, 0.0.0.0/0 to allow all IP addresses access, or another CIDR range.
Default value |
Description |
Server instance type |
Choose the node type for the Server node instances. |
Server instance count |
Choose the number of nodes to be deployed as Server node instances. |
Agent instance type |
Choose the node type for the Agent node instances. |
Agent instance count |
Choose the number of nodes to be deployed as Agent node instances. |
GPU agent instance type |
Choose the node type for the GPU Agent node instance. |
Task Mining agent instance type |
Choose the node type for the Task Mining Agent node instance. |
AS Robots agent instance type |
Choose the node type for the AS Robots Agent node instance. |
AS Robots agent instance count |
Choose the number of nodes to be deployed as AS Robots Agent node instances. |
Default value |
Description |
Instance key pair |
Existing key pair to connect to virtual machine (VM) instances. |
IAM role ARN |
ARN of a pre-deployed IAM Role with sufficient permissions for the deployment. Leave empty to create a new role automatically during deployment. |
IAM role name |
Name of a pre-deployed IAM role with sufficient permissions for the deployment. Leave empty to create a new role automatically during deployment. |
Default value |
Description |
Enable cluster backup |
Enable the cluster backup. |
Use a shared bucket for external storage |
Enable a shared bucket across products. If enabled, Process Mining and Data Service still require a dedicated bucket each. |
Load balancer |
Select either an Application Load Balancer (ALB) or a Network Load Balancer (NLB). If you select a Network Load Balancer, then you need to manually configure the TLS certificates post deployment. |
Ingress Security Group CIDR (for https) | Empty string | Ingress Security Group CIDR (for HTTPS). Set the CIDR to
allow access to Automation Suite. Set the CIDR to
another CIDR range.
Perform installation |
Perform the Automation Suite installation. Choose
false to perform only infrastructure provisioning and configuration.
Automation Suite version |
e.g.
2023.10.1 |
Automation Suite version to install |
Add GPU-enabled VMs |
Choose
true to add a GPU-enabled VM to the deployment.
Extra configuration keys |
Extra configuration keys to add to the cluster configuration. Leave empty to use the default configuration. |
Validity of the self-signed certificate |
| Validity (in days) of the self-signed certificate that the deployment uses to encrypt traffic inside the VPC. |
Disable presigned URL |
Enable or disable objectstore access via pre-signed URLs. |
Default value |
Description |
External registry Fully Qualified Domain Name |
FQDN for the external registry. Leave empty to not use an external registry. |
External registry user name |
User name for connecting to the external registry. Leave empty to not use an external registry. |
External registry password |
Password for connecting to the external registry. Leave empty to not use an external registry. |
Default value |
Description |
Service install flags (multiple) |
Choose if a specific service is installed in the cluster. |
Default value |
Description |
Connect AI Center to an external Orchestrator |
Register AI Center to an external Orchestrator. |
Orchestrator URL |
URL of the external Orchestrator to which AI Center connects. Example:
https://my-orchestrator.net |
Identity URL |
URL of the Identity server used to authorize AI Center. Example:
https://my-orchestrator.net/identity |
Base64 encoded Orchestrator certificate |
Base64 encoded Orchestrator certificate string Example:
UExBQ0VIT0xERVI= |
Base64 encoded Identity certificate |
Base64 encoded Identity certificate string Example:
UExBQ0VIT0xERVI= |
Default value |
Description |
Hosting FQDN |
Fully qualified domain name (FQDN) for Automation Suite. This must be either a subdomain or root domain of the
ID of Amazon Route 53-hosted zone parameter.
ID of Amazon Route 53-hosted zone |
Enter the ID of the Amazon Route 53-hosted zone or leave blank. For details, see Valid domain name. |
ARN of the ACM-hosted certificate |
ARN of the certificate present in the Amazon Certificate Manager (ACM) to use with the ALB. Leave empty to create the public certificate during deployment. |
Use internal load balancer |
Choose if you want to use an internal load balancer. |
Default value |
Description |
Engine of SQL Server deployed on Amazon RDS |
Choose the Amazon Relational Database Service (Amazon RDS) SQL engine |
Version of SQL Server deployed on Amazon RDS |
Choose the Amazon RDS SQL version. |
AWS KMS Key Id used to encrypt Amazon RDS storage |
KMS Key ID to use for the encryption of the Amazon RDS storage. Leave empty to skip encrypting the Amazon RDS storage. |
- Table 1. Network choice
- Table 2. Network configuration
- Table 3. Availability Zone configuration
- Table 4. Common networking configuration
- Table 5. Automation Suite node configuration
- Table 6. Automation Suite instance configuration
- Table 7. Automation Suite deployment configuration
- Table 8: Automation Suite external registry configuration
- Table 9. Automation Suite service configuration
- Table 10. Automation Suite external Orchestrator configuration
- Table 11. DNS or SSL configuration
- Table 12. Amazon RDS configuration
