Last updated Apr 22, 2026
Performing Insights database maintenance
Insights Database works using two tables: dbo and read. Both tables store data from Orchestrator databases and pass data between each other. Over time, tables store a large amount of data that can impact database performance. You can free up space by removing data that is not relevant or outdated.
The estimated threshold for storing historical data is set to
  • Up to 100 million jobs
  • Up to 1 billion job events
  • Up to 100 million queue items
  • Up to 500 million queue item events
  • Up to 1 billion robot logs
Use the following database maintenance SQL scripts to create SQL Stored Procedures, then execute these SQL Stored Procedures to either delete all data from [dbo].Jobs, [dbo].JobEvents, [dbo].QueueItems, [dbo].QueueItemEvents, [dbo].RobotLogs tables, or just the [dbo].RobotLogs.
Note:
Back up your database before executing the scripts. Before running the PROCEDURE [read].[Delete_Insights_Data_Read] and PROCEDURE [read].[Delete_Process_Logs_Read] scripts, the Insights module needs to be disabled.
Considerations
  • Scripts with the _DBO suffix are used to delete data from DBO schema tables,
  • Scripts with the _Read suffix are used to delete data from Read schema tables.
  • Large-sized batches might impact the speed of execution. Consider using the default batch size, which is set to 100000.
Prerequisites
  1. Log in to the Automation Suite cluster.
  2. Remove files that may conflict with the commands:
    rm -f appsettings.json
  3. Get the current settings:
    ./bin/uipathctl config orchestrator get-config --app-settings > appsettings.json || echo '{}' > appsettings.json
    Note:
    Ignore the following message if it is displayed: Cannot print custom config: Orchestrator custom config is missing appsettings.. This error message only implies there are no custom settings.
  4. Add the Insights.ModuleEnabled key and set it to False:
    jq '.["Insights.ModuleEnabled"] = "false"' appsettings.json > temp.json && mv -f temp.json appsettings.json
  5. Update the configuration:
    ./bin/uipathctl config orchestrator update-config --app-settings appsettings.json
  6. Validate the configuration:
    The expected result is as follows:
        "Insights.ModuleEnabled": "false"
    The result can contain other settings unrelated to Insights.
  7. Run the maintenance scripts. After you run the maintenance script, re-enable Insights using the following steps.
  8. Remove any conflicting files:
  9. Remove the Insights.ModuleEnabled key:
    jq 'del(.["Insights.ModuleEnabled"])' appsettings.json > temp.json && mv -f temp.json appsettings.json
  10. Update the configuration:
  11. Confirm the configuration:
Resources
SQL stored procedure 1: delete all data based on cut-off timestamp
Generate and save the following SQL Stored Procedures to delete all data types (Jobs, JobEvents, QueueItems, QueueItemEvents, RobotLogs) for a cut-off timestamp.
SQL Stored Procedures Parameter Description
Delete_Insights_Data_DBO
  • @CutoffTimeStamp DATETIME (Required) Delete all five types of data before a specified timestamp (e.g., 2021-01-01 01:00:05 ).
    Do not provide a timestamp that deletes all data to an empty table.
  • @BatchSize INT = 100000 (Optional) Default is set to 100000 .
    Data is deleted batch by batch. For example, if you have 1 million RobotLogs and leave the default value, the delete command runs ten times to remove all data.
Delete data from [dbo].[Jobs] , [dbo].[JobEvents] , [dbo].[QueueItems] , [dbo].[QueueItemEvents] , [dbo].[RobotLogs] tables based on a cut-off timestamp.
Delete_Insights_Data_Read N/A Truncate [read].Jobs , [read].JobEvents , [read].QueueItems , [read].QueueItemEvents , [read].RobotLogs tables.
Note:
The Insights Dashboard widgets are available again after SQL Stored Procedure 1 has finished, and the data has been backfilled. Keep in mind that the backfill process may take hours to complete given that you have a large amount of data. When you first run the Delete_Insights_Data_DBO SQL Script, it creates a QueueItems.IX_CreationTime nonclustered index with the purpose of making future executions faster.
SQL stored procedure 2: delete RobotLogs data based on ProcessNames and Tenant ID
Generate and save this SQL Stored Procedure to delete RobotsLogs based on ProcessNames and Tenant ID.
Delete_Process_Logs_DBO
  • @ProcessName NVARCHAR(128) (Required)
The Orchestrator process name.
  • @TenantId INT (Required)
Tenant ID is required as two tenants might run processes with identical names.
Delete data in batches of 100000. See Considerations .
Delete data from [dbo].[RobotLogs] table by ProcessName and Tenant ID.
Truncate [read].RobotLogs table.
Note:
The Insights Dashboard widgets related to RobotLogs are available again after SQL Stored Procedure 2 has finished, and the data has been backfilled. Keep in mind that the backfill process may take hours to complete given that you have a large amount of data.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
