- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- AI Center-specific configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
- Exploring summarized telemetry
- Only Microsoft ODBC Driver 17 is supported.
- SQL Server 2016 and 2017 are not supported in Automation Suite versions from 2024.10.3 onward. SQL Server 2019 or later is supported starting with Automation Suite version 2024.10.3.
Each product in Automation Suite requires its own SQL database with corresponding specifications.
By default, the installer creates all the databases for you during the installation process. You must provide the necessary permissions for the installer to do so on your SQL server.
Alternatively, you can create your own databases. Refer to the following table for the names you need to use.
If you choose to bring your own databases for a new Automation Suite installation, we strongly recommend setting up new databases rather than using existing ones. This precaution is necessary to prevent any conflicts with the operation of Automation Suite that might occur due to leftover metadata from old databases.
The following table lists out the database names and their corresponding format.
Product / service |
Default database name |
Connection string format |
Shared Platform Capabilities |
Orchestrator |
Action Center |
Automation Suite Robots |
Automation Hub |
| Automation Ops | AutomationSuite_Platform | ADO.NET |
Data Service |
Insights |
Test Manager |
Task Mining |
AI Center |
Apps | AutomationSuite_Apps1 | ODBC |
Document Understanding |
Process Mining2 |
AutomationSuite_ProcessMining_Warehouse3AutomationSuite_Airflow 45 |
2 To minimize latency issues, it is strongly recommended to deploy the Process Mining databases in the same region as the compute resource (Kubernetes cluster).
AutomationSuite_ProcessMining_Warehouse uses both ADO.NET and PYODBC formats.
AutomationSuite_Airflow PostgreSQL database use SQLAlchemy connection string format. The connection to the AutomationSuite_Airflow database can not begin with a { character.
AutomationSuite_Airflow Microsoft SQL Server database uses SQLAlchemy connection string format. AutomationSuite_Airflow must have READ_COMMITTED_SNAPSHOT enabled when creating databases manually. The connection to the AutomationSuite_Airflow database can not begin with a { character.
AutomationSuite_Airflow .
If you manually set the connection strings in the configuration file, you can escape SQL, JDBC, or ODBC passwords as follows:
- for SQL: add
'at the beginning and end of the password, and double any other'. - for JDBC/ODBC: add
{at the beginning of the password and}at the end, and double any other}.
You could use the databases in an elastic pool for better cost-effectiveness.
SQL_Latin1_General_CP1_CI_AS at both the server and database level. We strongly recommend this particular setup for optimum performance and stability.
While you have the flexibility to use a collation of your choice, be aware that untested configurations can potentially lead to unexpected issues.
We do not recommend using Binary SQL or any collations that are case-sensitive, as they cause known issues while installing Automation Suite.
dbcreator role to the SQL account used to connect to
the database.
db_owner role for all Automation Suite databases.
db_owner, then the SQL
account should have the following roles and permissions on all databases (the only
exception is Insights which still requires db_owner).
db_securityadmindb_ddladmindb_datawriterdb_datareaderEXECUTEpermission on dbo schema
db_securityadmin and db_ddladmin roles during
installation or if the databases are reprovisioned, so you may revoke these permission
afterwards.
Only the listed SQL ciphers are supported in Automation Suite:
TLS_AES_256_GCM_SHA384TLS_CHACHA20_POLY1305_SHA256TLS_AES_128_GCM_SHA256TLS_AES_128_CCM_SHA256ECDHE-ECDSA-AES256-GCM-SHA384ECDHE-RSA-AES256-GCM-SHA384ECDHE-ECDSA-CHACHA20-POLY1305ECDHE-RSA-CHACHA20-POLY1305ECDHE-ECDSA-AES256-CCMECDHE-ECDSA-AES128-GCM-SHA256ECDHE-RSA-AES128-GCM-SHA256ECDHE-ECDSA-AES128-CCMECDHE-ECDSA-AES128-SHA256ECDHE-RSA-AES128-SHA256ECDHE-ECDSA-AES256-SHAECDHE-RSA-AES256-SHAECDHE-ECDSA-AES128-SHAECDHE-RSA-AES128-SHAAES256-GCM-SHA384AES256-CCMAES128-GCM-SHA256AES128-CCMAES256-SHA256AES128-SHA256AES256-SHAAES128-SHADHE-RSA-AES256-GCM-SHA384DHE-RSA-CHACHA20-POLY1305DHE-RSA-AES256-CCMDHE-RSA-AES128-GCM-SHA256DHE-RSA-AES128-CCMDHE-RSA-AES256-SHA256DHE-RSA-AES128-SHA256DHE-RSA-AES256-SHADHE-RSA-AES128-SHAPSK-AES256-GCM-SHA384PSK-CHACHA20-POLY1305PSK-AES256-CCMPSK-AES128-GCM-SHA256PSK-AES128-CCMPSK-AES256-CBC-SHAPSK-AES128-CBC-SHA256PSK-AES128-CBC-SHADHE-PSK-AES256-GCM-SHA384DHE-PSK-CHACHA20-POLY1305DHE-PSK-AES256-CCMDHE-PSK-AES128-GCM-SHA256DHE-PSK-AES128-CCMDHE-PSK-AES256-CBC-SHADHE-PSK-AES128-CBC-SHA256DHE-PSK-AES128-CBC-SHAECDHE-PSK-CHACHA20-POLY1305ECDHE-PSK-AES256-CBC-SHAECDHE-PSK-AES128-CBC-SHA256ECDHE-PSK-AES128-CBC-SHARSA-PSK-AES256-GCM-SHA384RSA-PSK-CHACHA20-POLY1305RSA-PSK-AES128-GCM-SHA256RSA-PSK-AES256-CBC-SHARSA-PSK-AES128-CBC-SHA256RSA-PSK-AES128-CBC-SHA
Document Understanding requires the SQL Server to have the Full-Text Search component of the SQL Server Database Engine, which is not always installed by default.
If you did not select Full-Text Search when you installed SQL Server, run SQL Server Setup again to add it before configuring Document Understanding.
For more info, check this guide on how to add/install features on SQL server. You can also check here all the components that can be added to the SQL Server, which includes also Full-Text Search.
.json functions. SQL Server Enterprise is recommended due to more
efficient threading and scalability.
For Azure SQL, ensure the database is S3 service objective or higher.
Make sure the compatibility level for Insights database is set to 130 or higher. In most cases, the default settings meet this requirement. For more info, refer to View or Change the Compatibility level of a Database - SQL Server.
The installation validates both conditions and alerts you if minimum requirements are not met.
Data Service requires SQL Server version 2016 or higher.
If you create your own database using SQL Server version 2019 or higher, make sure to grant the following Data Service permissions to your users:
GRANT ALTER ANY SENSITIVITY CLASSIFICATION TO {userName};
GRANT VIEW ANY SENSITIVITY CLASSIFICATION TO {userName};GRANT ALTER ANY SENSITIVITY CLASSIFICATION TO {userName};
GRANT VIEW ANY SENSITIVITY CLASSIFICATION TO {userName};AutomationSuite_Airflow.
AutomationSuite_Airflow database, as PostgreSQL runs with the latest versions of Apache Airflow. Running the latest version of Airflow ensures you
make use of new functionality, performance, and security fixes.
If you choose not to use a PostgreSQL database and keep using a Microsoft SQLServer database, Process Mining on Automation Suite will run with legacy Airflow. Legacy versions of Apache Airflow may lack functionality, performance, and security fixes.
AutomationSuite_Airflow database.
For Process Mining on Automation Suite 2024.10.3 or higher versions, you can choose to use a PostgreSQL database for the AutomationSuite_Airflow database.
AutomationSuite_Airflow. The PostgreSQL database for Airflow will not be created automatically by the installer.
When migrating from Microsoft SQL Server to PostgreSQL database data migration is not required. With a correct configuration setup, the database is rebuild when running Sync Airflow.
Supported PostgreSQL versions
PostgreSQL versions 12.x to 16.x are supported. It is recommended to use the most recent version of PostgreSQL within this range for optimal compatibility and performance.
Hardware requirements
The machine on which the PostgreSQL database for Airflow is installed must meet the following harware requirements.
Cores: 4
Memory: 16 GiB
Storage: 64 GiB
IOPS: >=500 IOPS
Required permissions
The PostgreSQL Airflow user (or any dedicated database user) must have
"All Privileges" permissions for the designated Airflow database.
"all grants" on the server’s public schema.
"search_path" set to "public".
pg_hba.conf to add the Airflow user to the database access control list and reload the database configuration to apply the changes.
CREATE DATABASE airflow_db
WITH ENCODING 'UTF8'
LC_COLLATE='en_US.UTF-8'
LC_CTYPE='en_US.UTF-8'
TEMPLATE template0;
CREATE USER airflow_user WITH PASSWORD 'airflow_pass';
GRANT ALL PRIVILEGES ON DATABASE airflow_db TO airflow_user;
-- PostgreSQL 15 requires additional privileges:
GRANT ALL ON SCHEMA public TO airflow_user;
TEMPLATE template0;
SELECT pg_encoding_to_char(encoding) AS encoding
FROM pg_database
WHERE datname = 'airflow_db';SELECT pg_encoding_to_char(encoding) AS encoding
FROM pg_database
WHERE datname = 'airflow_db';Refer to the official Airflow documentation for more information on how to set up a PostgreSQL database for Airflow.
Default server port
5432. If you are using the PgBouncer connection pooler, it is common to use port 6432.
5432.
Sample connection string:
postgresql+psycopg2://testadmin:<password>@test-cu231009v3-postgresql.postgres.database.azure.com:5432/automationsuite_airflowpostgresql+psycopg2://testadmin:<password>@test-cu231009v3-postgresql.postgres.database.azure.com:5432/automationsuite_airflowpostgresql+psycopg2://kerberos_user:@kerberospostgres.AUTOSUITEAD.LOCAL:5432/automationsuite_airflowpostgresql+psycopg2://kerberos_user:@kerberospostgres.AUTOSUITEAD.LOCAL:5432/automationsuite_airflowpostgresql+psycopg2://testmanagedidentity:@test-postgresql-1.postgres.database.azure.com/airflow-ci-sfasaksqacu8524745postgresql+psycopg2://testmanagedidentity:@test-postgresql-1.postgres.database.azure.com/airflow-ci-sfasaksqacu8524745The default server port can be configured to use any available port as per your system requirements.
PgBouncer
Since Airflow uses short-lived connections, it is highly recommended to set up PgBouncer. PgBouncer is a lightweight connection pooler for PostgreSQL.
Refer to the official PgBouncer documentation for more information on how to set up PgBouncer.
AutomationSuite_Airflow database, Microsoft SQL Server is the only option available for Process Mining on Automation Suite versions 2024.10.2 and
earlier. For Process Mining on Automation Suite 2024.10.3 or higher versions, you are recommended to move to PostgreSQL.
AutomationSuite_Airflow database, make sure you meet the following requirements.
1433 for Airflow database connections.
Non-standard SQL Server ports are not supported.
When setting up Microsoft SQL Server make sure that the timezone of the SQL Server machine where the Airflow database is installed, is set to UTC.
AutomationSuite_ProcessMining_Warehouse for data storage for Process Mining process apps.
To ensure proper functioning of Process Mining, it is recommended to use Microsoft SQL Server 2022.
AutomationSuite_ProcessMining_Warehouse.
To calculate the hardware requirements, you need to have an indication of:
- the number of (million) events in your process.
the number of case and event fields in your output data.
Note: In a development environment, for performance reasons, it is recommended to work on a small development dataset with a limited number of records.
You can use the UiPath Automation Suite Install Sizing Calculator to determine the hardware requirements for setting up a dedicated Microsoft SQL Server machine for Process Mining. When you add Process Mining to the Product section, the minimum requirements for 1 Dedicated SQL Server are displayed.
Refer to Hardware requirements for more informations.
db_securityadmin database-level role both during and post-installation to enable per app security on the Process Mining data warehouse SQL
Server. For details, see the official Microsoft documentation on Database-level roles.
Refer to Configuring process app security for more information.
It is recommended to enable case sensitivity in table and column names using the following command:
ALTER DATABASE AutomationSuite_ProcessMining_Warehouse COLLATE SQL_Latin1_General_CP1_CS_AS
This prevents errors when loading data caused by columns with similar names, such as ID and id. It also ensures that textual values differing only in capitalization are treated as distinct. For example:
'activity 1' == 'activity 1''Activity 1' != 'activity 1'
Requirements for AI Center connected to an external Orchestrator
AutomationSuite_Platform for
AI Events and AI Storage services.
Requirements for AI Center installed on a FIPS 140-2-enabled machine
Before starting the Automation Suite installation, take the following steps:
Enable FIPS 140-2 on the machine on which you plan to install Microsoft Server by following the Microsoft instructions.
Install Microsoft SQL Server on the FIPS 140-2-enabled machine.
Get the Microsoft SQL Server certificate by running the following command from the SQL Server or any server that can connect to the SQL server with the configured SQL host name:
nmap -sV -p <port> -vv --script ssl-cert domainnmap -sV -p <port> -vv --script ssl-cert domain
During the Automation Suite installation, take the following steps:
Append the following values to the AI Center
sql_connection_string_template_jdbcconnection string in thecluster_config.jsonfile:encrypt=true;trustServerCertificate=false;fips=true;.Example:
jdbc:sqlserver://sfdev1804627-c83f074b-sql.database.windows.net:1433;database=DB_NAME_PLACEHOLDER;user=testadmin;password=***;encrypt=true;trustServerCertificate=false;fips=true;Connection Timeout=30;hostNameInCertificate=sfdev1804627-c83f074b-sql.database.windows.net"jdbc:sqlserver://sfdev1804627-c83f074b-sql.database.windows.net:1433;database=DB_NAME_PLACEHOLDER;user=testadmin;password=***;encrypt=true;trustServerCertificate=false;fips=true;Connection Timeout=30;hostNameInCertificate=sfdev1804627-c83f074b-sql.database.windows.net"For details on database configuration, see Advanced installation experience and Updating the SQL database.
Add the exported cert from step 1.c. to the trust store of the host machine. For details see Updating the CA Certificates.
For a high-availability configuration of your SQL Server, select an Always On availability group. For more info, refer to Overview of Always On availability groups.
READ_COMMITTED_SNAPSHOT option is set to ON.
READ_COMMITTED_SNAPSHOT is enabled or disabled:
SELECT is_read_committed_snapshot_on FROM sys.databases
WHERE name like 'PLACEHOLDER' SELECT is_read_committed_snapshot_on FROM sys.databases
WHERE name like 'PLACEHOLDER' Make sure to replace PLACEHOLDER with your Orchestrator database name.
1.
0. Use this query to enable it:
ALTER DATABASE PLACEHOLDER
SET READ_COMMITTED_SNAPSHOT ONALTER DATABASE PLACEHOLDER
SET READ_COMMITTED_SNAPSHOT ONREAD_COMMITTED_SNAPSHOT must be enabled on those as well.
- Databases
- SQL collation
- Permissions
- SQL server ciphers
- SQL requirements for Full-Text Search
- SQL requirements for Insights
- SQL requirements for Data Service
- SQL requirements for Process Mining
AutomationSuite_AirflowPostgreSQL databaseAutomationSuite_AirflowMicrosoft SQL Server databaseAutomationSuite_ProcessMining_Warehousedatabase- SQL requirements for AI Center
- Requirements for AI Center connected to an external Orchestrator
- Requirements for AI Center installed on a FIPS 140-2-enabled machine
- SQL requirements for HA
- SQL requirements for Orchestrator
