- Release notes
- Before you begin
- Getting started
- Integrations
- Working with process apps
- Working with dashboards and charts
- Working with process graphs
- Working with Discover process models and Import BPMN models
- Showing or hiding the menu
- Context information
- Export
- Filters
- Sending automation ideas to UiPath® Automation Hub
- Tags
- Due dates
- Compare
- Conformance checking
- Root cause analysis
- Simulating automation potential
- Viewing Process data
- Creating apps
- Loading data
- Transforming data
- Customizing dashboards
- Publishing Dashboards
- App templates
- Notifications
- Additional resources
Architecture overview
Process Mining
Last updated Jun 26, 2025
This page provides an overview the architecture of Process Mining. Process Mining extracts data from source systems (for example, SAP, Salesforce, ServiceNow), transforms it into event logs, and displays it in interactive process dashboards.
Users access the Process Mining portal to interact with dashboards that visualize their processes.
The Process Mining engine is responsible for:
Data transformation: Moving the data from blob storage to the data warehouse, and transforming the data for use in the dashboards.
Dashboard interaction: Calculating the process graph, charts and KPIs shown in dashboards.
Users have the option to either directly upload data files in the portal or utilize extraction tools to extract data from source systems and subsequently upload it to dedicated blob storage.
