Process Mining
Working with process graphs
Introduction​
A process graph is a visual representation of the order in which events took place based on the data.
TRACY​
TRACY is a technique that defines the layout of process graphs. TRACY lets your process graph look like how you would draw a process yourself. When drawing a process, you normally begin with the start activity and finish with the end activity of the process. In between, you try to position all other activities in their executed order. TRACY takes the overall flow of your process into account and displays this as the main flow in your process graph. With TRACY all the activities of your process are positioned and ordered in a way that makes sense. This helps you to more easily understand your processes When changing data, TRACY minimizes changes to the process graph. When you use process filters to display happy paths or to filter out data, TRACY keeps the layout of the process graph as stable as possible. When you are analyzing a process, the process graph now always looks about the same, no matter which dashboard you are using, or which filters you have applied. This make analyzing your process easier.
TRACY smoothly animates the transitions between filter states. This helps you to understand what happens when you are filtering.
The process graph​
Important:
Processes can be quite large when all variations are included. To keep the visualization understandable, the process graph automatically selects the most frequently traveled paths in your process. It is limited to displaying a maximum of 1,000 edges at once.
If this limit is reached and you see the “Too much data” message, we recommend the following:
  • Use the variant slider to reduce the number of displayed variants.
  • Apply additional filters relevant to your analysis. You can do this manually through the filter sidebar or by using supporting charts to drill down into specific parts of your process.
The process graph consists of the activities of your workflow and edges which represent the transitions in between the activities. The following illustration shows an example.
The activities vary in color. Also, there is a difference in the thickness of several edges. In the process graph, both these colors and the thickness of the edges, indicate the number of objects going through the activities/edges.
Also, the number of objects going through this process is shown on the edges.
The legend at the top left shows the metric used in the process graph. Beneath the legend the minimum and maximum numbers are displayed. The legend colors correspond to the colors of the Activities and Edges (transitions) in the process graph.
Note:
The metric of each process graph can be different. The bars and the thickness of the edges can represent a different metric on each graph. They can also differ from each other.
Event order​
The order of the events in the process graph is defined by the following fields (in this order):
  1. Event_end (the end timestamp),
  2. Activity_order (if defined),
  3. Activity,
  4. Event_ID.
By default, events are ordered by Event_end.
It is also possible to define Activity_order. If Activity_order is set, and the ties cannot be solved by Event_end, the events will be ordered according to the specified Activity_order field. If Activity_order is set only on a subset of acitivities that are in the tie, the activities that don’t have Activity_order set take precedence. Check out Designing an event log.
Viewing process graph information​
Hovering over an edge or activity triggers a hint which includes all kinds of information. For example, the throughput time of activities and edges. Also, when hovering over an activity or edge, the connections are highlighted in color. Hints can be different for each process graph. The following illustration shows an example.
Start and end activities​
The start and end activities are not actual activities in the process. In a process graph, these activities indicate the start and end of the process graph. A start activity is identified by the activity icon and an end activity is identified by the icon.
Details Slider​
The Details slider enables you to reduce the complexity of the process graph, which will increase the readability of the graph. By default, the detail of the process graph is automatically determined. You can use the Details slider to change the number of activities and/or edges shown.
If the Details slider is set to ...Then ...
Defaultthe most optimal readability detail for the process graph will be detected automatically.
Maximumevery possible path in the process is shown in the process graph.
Minimumonly the most important path in the process is shown in the process graph from start to end, where all other paths are hidden.
Any other positionthe most important paths of the process are displayed according to the selected position.
If you have changed the default setting of the Details slider you can click on Reset to default to set the detail of the process graph back to the optimal setting. See the illustration below.
Note:
The Reset to default option is only enabled if you changed the default setting of the Details slider.
Zoom in/zoom out​
You can use the zoom in/zoom out buttons at the bottom to change the magnification of the process graph. The following table describes the buttons.
Button Select to ...
Zoom in button
Zoom in
Zoom out button
Zoom out
Reset to default button
Reset to the default view
Note:
You can also use the mouse wheel to zoom in or zoom out.
Viewing the Process Based on a Different Metric​
A process graph can contain metric selectors for activities and edges. See the illustration below.
Follow these steps to select a different metric for the process graph.
StepAction
1Click on the metric selector in the process graph.
2Select a different metric from the list of available metrics.
See the illustration below for an example.
The value for the selected metric is displayed on the activities in the process graph. See the illustration below, where the number of cases is displayed for the activity.
Note:
The process graph only updates after you select a different activity metric. This implies that if you select a different edge metric, you must select a different activity metric in order to update the process graph.
Using the Context Menu​
You can right-click on an activity or edge to open the context menu. See the illustration below.
Below is a description of the elements.
Element Description
docs image
Displays available filter options.
docs image
Displays available options for exporting the process graph. See Export.
docs image
Displays the process graph in full-screen mode.
docs image
Displays the Send to Automation Hub form, where you can enter the details for an idea for automation. See Sending automation ideas to UiPath Automation Hub.
Connect
Stay updated
