Process Mining
Create a destination connection
To set up a SQL Server destination connection you need the following setup parameters for the SQL Server database.
  • Server
  • Database
  • Schema
  • Role
Follow these steps to create the SQL Server destination connection.
  1. Define a new connection of type SQL Server.
  2. Enter a descriptive name for the destination connection. For example SQLServer_IM.
  3. Configure the Settings to connect to your SQL Server database using the SQL Server database setup credentials retrieved
    Note:
    Server must be specified as <Server>,<Port>.
    Note:
    User / Password must be the SQL credentials of the user that has permissions to write into the database. Check out Setting up a SQL Server account for data upload using an extractor. Password may not contain a semicolon ;.
  4. Create and test the connection.
Connect
Stay updated
