Process Mining
2023.4.1
Addendum: July 12, 2023​
New app templates available​
The following app templates are now available for download on the UiPath Customer Portal:
  • SAP-Accounts-Payable
  • SAP-Ariba-Vendor-Sourcing
DataBridgeAgent​
A new version of the DataBridgeAgent is now available.
Release date: June 27, 2023​
We are constantly working to improve your UiPath Process Mining experience. Even though there are no major significant changes with this release, we made sure to bring security improvements and minor bug fixes to our product.
What is new​
Managed Kubernetes Services​
You can now install Process Mining via Automation Suite on Azure Kubernetes Service (AKS) and Amazon Elastic Kubernetes Service (EKS). Automation Suite on EKS/AKS allows you to bring your own Kubernetes cluster, dedicated for Automation Suite and managed by you.
Maximum number of activities​
When uploading a dataset with too many activities, Process Mining may become unresponsive. A warning message is now displayed when you try to upload a dataset that contains more than 500 activities.
Upgrade reminder for process apps​
With the introduction of TRACY in Process Mining 2023.4, all new process apps will use TRACY for the process graph layout. Existing process apps will continue to work in Process Mining 2023.4.1, but will show a banner or a warning message to indicate that the layout is no longer supported.
Recreate or migrate your process apps before October 2023 (Process Mining 2023.10), to make sure the process apps are still accessible.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
