- Release notes
- Before you begin
- Getting started
- Integrations
- Managing access
- Working with process apps
- Creating apps
- Loading data
- Uploading data
- Setting up a SQL Server account for data upload using an extractor
- Loading data using Theobald Xtract Universal
- Customizing process apps
- Data transformations
- TemplateOne app template
- Purchase to Pay app template
- Order to Cash app template
- Basic troubleshooting guide
Process Mining
Last updated Apr 15, 2025
Attention:
There can be issues with loading data using an Azure Blob destination connection for existing process apps when using CData Sync versions 2025 - 25.1.x. We strongly recommend using CData Sync 2024 - 24.1.x versions instead and advise against upgrading to CData Sync 2025 - 25.1.x versions.
Note: The information in this page is based on CData Sync 2024 - 24.1.8885. If you use an other version of CData Sync, field names or functions may be different.
CData Sync is a tool that is used to extract data from source systems into Process Mining. The supported source systems can be found on the Sources page on the CData Sync website. Refer to the official CData Sync website for more information on CData Sync.
This page describes how to use CData Sync to load data from your source system into a process app in Process Mining.
It is assumed that you have:
- a valid CData Sync license.
Note: The license is provided via UiPath® for the purpose of Process Mining.
- set up SQL Server access with the correct permissions. Refer to
