- Release notes
- Before you begin
- Getting started
- Integrations
- Managing access
- Working with process apps
- Creating apps
- Loading data
- Uploading data
- Setting up a SQL Server account for data upload using an extractor
- Loading data using Theobald Xtract Universal
- Customizing process apps
- Data transformations
- TemplateOne app template
- Purchase to Pay app template
- Order to Cash app template
- Basic troubleshooting guide
- Process Mining troubleshooting and FAQs
Introduction
The purpose of this Troubleshooting page is to serve as a knowledge base for common problems faced or questions asked when using UiPath® Process Mining. It does not provide a complete list of all problems you may encounter, but is intended to provide guidance with the most common issues. If you encounter any issues that are not covered here, feel free to reach out to UiPath® Technical Support.
Message: The HTTP status code of the response was not expected (500)
When creating a new process app using sample data, the following error message can occur:
Possible cause
A SQL Server password has changed. Check out Configuring Microsoft SQL Server.
Solution
Update Automation Suite when changing SQL Server credentials.
Message: File upload failed due to the following error: Network error
When uploading data using .csv or .tsv files, the following error message can occur:
Possible cause
Incorrect or missing HTTPS certificate.
Solution
The HTTPS certificate used by the BLOB store must be valid in your browser. Check the error and make sure to get the appropriate certificates.
- Go the Process Mining portal and press F12 to open the Developer tools.
Check the Console and Network tabs for the ERR: CERT_AUTHORITY_INVALID error. This indicates an error with the trust of the HTTPS certificate. The following illustration shows an example.
- Contact your IT department to install the certificate chain of the authority listed in the error and to add it to the trusted certificate store in operating system for all user that will be using the system. For example, pmcprddatawesa.blob.core.windows.net.
Message: utf-8 codec can't decode byte <byte> in position <position>: Invalid start byte
The following message is displayed in the data run log.
Possible cause
One or more input files you uploaded have an unexpected encoding.
Solution
Set the encoding to UTF-8 and set CR/LF end of line characters (Windows style).
You can change these settings in a file editor. For example in Notepad++.
Open the datasource file in Notepad++.
Go to Edit -> EOL Conversion and select Windows CR LF.
Go to Encoding and select Convert to UTF-8.
Save the file.
Connection error: The TCP/IP connection to the host <host>, port <port> has failed.
The following message is displayed when setting up a SQL Server destination connection in CData Sync.
Possible cause
There is an issue with CData Sync connecting to SQL Server.
Solution
Open SQL Server Configuration Manager.
Check the TCP Port number.
Check if TCP/IP is set to Enabled for the Port. The following illustrations shows an example.
Message: [Errno 2] No such file or directory: '/dbt/dags/workflows/execdbt//target/4212eba4-1edc-4b9c-9c04-1d59c2bfe0af/run_results.json'
Possible cause
The content of the uploaded transformation package is incorrect, by an incorrect zip action.
Solution
Make sure the content of the .zip file that contains the transformations is correct.
Possible cause
Kerberos setup is used for login to Automation Suite and Kerberos setup is not used for SQL authentication. The enableSqlIntegratedAuth configuration flag determines whether or not integrated SQL authentication setup is used for SQL authentication. If the enableSqlIntegratedAuth configuration flag is set to true, this implies that Kerberos setup is not used for authentication. To solve the issue, the enableSqlIntegratedAuth configuration flag must set to false which disables integrated SQL authentication and ensures that Kerberos setup is used for authentication.
Possible solution
Follow these steps to set the enableSqlIntegratedAuth flag to false.
In the ArgoCD Experience, enter Airflow in the search bar and open the card.
Select App Details and go to the Details tab.
Edit the VALUES and set the flag
enableSqlIntegratedAuthto false. Select SAVE. -
Locate the SYNC POLICY section and set AUTOMATED to DISABLE AUTO-SYNC for the Airflow app, to ensure the configuration flag
enableSqlIntegratedAuthwill not be brought back to true.
How to cancel a data run from the database
This section describes how to manually stop the data run from the database in case of a failing data run.
Follow these steps.
Retrieve the App ID of the process app for which you want to cancel the data run. Check outProcess App properties.
Contact you database administrator to run the following SQL query in the AutomationSuite_ProcessMining_Metadata database:
with Ingestion_tbl as (select top 1 * from dbo.Ingestions where AppId = '<app ID>' and [Status] = 1 order by LastUpdated desc) update Ingestion_tbl set [Status]=3where <app ID> should be replaced with the App ID retrieved in Step 1.The following illustration shows an example.
Refresh Process Mining Portal page.
Upload data for the process app.
When creating a process app the status stays in Creating app
Possible cause
The database service is not set correctly during installation or upgrade.
Solution
Make sure to configure the process app security. Check out Configuring process app security.
If you cannot update the SQL server permission, it is recommended to change the app_security_mode from system_managed to single_account.
- Introduction
- Message: The HTTP status code of the response was not expected (500)
- Possible cause
- Solution
- Message: File upload failed due to the following error: Network error
- Possible cause
- Solution
- Message: utf-8 codec can't decode byte <byte> in position <position>: Invalid start byte
- Possible cause
- Solution
- Connection error: The TCP/IP connection to the host <host>, port <port> has failed.
- Possible cause
- Solution
- Message: [Errno 2] No such file or directory: '/dbt/dags/workflows/execdbt//target/4212eba4-1edc-4b9c-9c04-1d59c2bfe0af/run_results.json'
- Possible cause
- Solution
- Possible cause
- Possible solution
- How to cancel a data run from the database
- When creating a process app the status stays in Creating app
- Possible cause
- Solution
