Process Mining
Using a credential store
A Credential store allows you to use passwords without showing the actual password. See Set up a Credential Store for a detailed description.
By default, an encrypted credential store is used. See Setting up an encrypted file-based credential store for more information.
Note:
To change the Server Settings you edit the <EXTRACTORDIR>\databases\ServerSettings.json file.
Connect
Stay updated
