Process Mining
Last updated Apr 15, 2025
Using .mvp Connectors
In Process Mining (Automation Suite), an existing Process Mining on-premises (standalone) connector (.mvp file) can be loaded using DataBridgeAgent. This enables you to reuse the existing Data transformations, and load the output data into a process app in Process Mining Automation Suite.
See Adding a Custom Connector to DataBridgeAgent for a detailed description on how to add a .mvp connector file created in Process Mining on-premises (standalone) to DataBridgeAgent.
