Last updated Nov 6, 2025
Estimating cloud infrastructure costs
On this page, we use the cloud templates as a reference point to evaluate the infrastructure costs required to support Automation suite. We also call out a few additional notes to help forecast the total cost of ownership for Automation Suite. The resulting estimates can approximate your future spending on infrastructure with high confidence for cloud deployments. You can also use the estimates as a reference point to compare the costs of physical bare-metal implementations.
Each cloud template deployment automatically provisions a set of components based on the provided inputs.
To check out the list of components for each cloud provider, see the following:
To calculate the cost of the infrastructure provisioned by the cloud templates based on your scenario needs, refer to the following guidelines and estimates.
Identifying the cost factors
There are multiple factors impacting the cost of the infrastructure deployed by the cloud templates, such as the following:
  • Number of server nodes
  • Server node instance type
  • Number of agent nodes
  • Number of GPU nodes
  • GPU node instance type
  • Products selected
Using the pricing calculator
You can accurately estimate the cost of your cloud infrastructure by taking the following steps:
  1. Determine the resources your scenario requires using the UiPath® Automation Suite Install Sizing Calculator.
  2. Use the pricing calculator of your public cloud provider:
Refer to the following examples to help you get started with the pricing calculators.
Estimate examples
The following table describes the multi-node HA-ready production infrastructure cost estimate for the Complete product selection in the context of the previously introduced guidelines.
The estimates do not account for the load balancers, Bastion, key vault, and backup.
AWS
Azure
3
Note: The estimate examples are based on public listed prices. To better match your current prices, contact your cloud provider.
Automation Suite vs. standalone products: infrastructure costs
Automation Suite seems to have a considerable infrastructure footprint. However, when comparing it with the total amount of infrastructure needed to run production use cases of standalone UiPath® products, the costs are similar and, in some cases, even lower for Automation Suite.
To give concrete examples of infrastructure cost differences between Automation Suite and standalone products, we leveraged the pricing calculators of cloud providers where possible, along with our hardware requirements. The following table summarizes the results:
Automation Suite Milestone
Product
Monthly cost in standalone
Monthly cost in Automation Suite
Yearly cost in Automation Suite
Link to estimate in Azure
Enterprise grade Orchestrator
Orchestrator
$2,250
$2,813
$33,756
Coming from standalone
Orchestrator
$2,850
$3,144
$37,728
Test Manager
Insights
Action Center
Modern basic platform
Orchestrator
N/A
$3,476
$41,712
Test Manager
Insights
Action Center
Data Service
Automation Hub
Automation Ops
Apps light
Orchestrator
N/A
$3,476
$41,712
Data Service
Apps
Modern platform with Apps
Orchestrator
N/A
$3,808
$45,696
Test Manager
Insights
Action Center
Data Service
Automation Hub
Automation Ops
Apps
Full platform + Document Understanding Starter
Orchestrator
N/A
$4,139
$49,668
Test Manager
Insights
Action Center
Data Service
Automation Hub
Automation Ops
Apps
AI Center
Scale to Document Understanding for every 50k pages/day
Extraction
$100
$1,200
D4 VM
Classification
$100
$1,200
D4 VM
OCR
$100
$2,400
NC4 VM
Task Mining
Task Mining on dedicated agent
N/A
$531
$6,372
B20Ms
Process Mining
Process Mining on dedicated agent
N/A
$498
$5,952
F16s v2 + SQL license
Automation Suite Robots
Automation Suite Robots on dedicated agent
N/A
$496
$5,925
F16s v2
In addition, the total costs of supporting Automation Suite are lower compared to standalone product deployments when considering the following:
  • Automation Suite requires fewer staff members to maintain operation since fewer machines must be managed as compared to standalone products.
  • The IT department does not require any new skills to support additional products because the Automation Suite instance management is the same regardless of which products are used. Therefore, Automation Suite required less IT staff to support the range of UiPath® products.
  • The infrastructure spend does not change significantly when adding new products to the Automation Suite instance and increasing its ROI (i.e., when adding Automation Hub).
  • Automation Suite also includes out-of-the-box monitoring, cluster management, as well as unified admin and end-user experiences across all products.
