Last updated Nov 6, 2025
Configuring the cluster
Configuration Tool
The configureUiPathAS.sh script helps you control and manage Automation Suite. The tool comes with the installation bundle and is available in the main installer folder. configureUiPathAS.sh is currently capable of performing only a few operations.
To view more information about configureUiPathAS.sh, run:
sudo ./configureUiPathAS.sh --helpsudo ./configureUiPathAS.sh --help
You should see the following output:
configureUiPathAS.sh controls and manage UiPath Automation Suites
Usage:
  configureUiPathAS.sh [command]
  configureUiPathAS.sh [flags]
Available Commands:
  config                               Manage cluster configuration
  tls-cert                             Manage tls and server certificate
  additional-ca-certs                  Manage additional ca certificates
  aicenter                             Manage aicenter standalone
  identity                             Manage identity service
  objectstore                          Manage objectstore
  registry                             Manage registry
  monitoring                           Manage monitoring
  rabbitmq                             Manage rabbitmq
  mongodb                              Manage mongo
  node                                 Manage k8s nodes
  enable-maintenance-mode              Enables maintenance mode on the Cluster
  disable-maintenance-mode             Disables maintenance mode on the Cluster
  is-maintenance-enabled               Checks if maintenance mode is enabled on the Cluster
  kubeconfig                           Manage the Kubernetes context
  resume-scheduled-backups             Resumes the paused scheduled backups
  verify-volumes-backup                Verify if all volumes are backed up
  gpu                                  Enable/Disable gpu on the cluster.
  telemetry                            Manage telemetry
  snapshot                             Manage cluster disaster recovery
Flags:
  -h|--help                            Display help
  -d|--debug                           Run in debug modeconfigureUiPathAS.sh controls and manage UiPath Automation Suites
Usage:
Available Commands:
Flags:
You can use the configureUiPathAS.sh script to manage the following components in the Automation Suite cluster:
  • Server Certificate - Manage tls and server certificate (update and get the certificate)
  • Additional CA Certificates - Manage additional CA certificates such as SQL server certificates, proxy server certificates, etc.
  • Identity service - Manage identity service configurations such as token signing certificate, SAML certificates, Kerberos and Windows authentication, etc.
  • Objectstore - Manage ceph objectstore (currently only supporting resizing of ceph pvc/storage)
  • Registry - Manage docker registry (currently only supporting resizing of registry pvc/storage)
  • Monitoring - Manage rancher server (currently only supporting resizing of rancher server pvc/storage)
  • RabbitMQ - Manage rabbitmq message queue (currently only supporting resizing of rabbitmq pvc/storage)
  • MongoDB - Manage mongodb datastore (currently only supporting resizing of mongodb pvc/storage and certificate management)
Updating the SQL Server connection
To update the connection string or credentials to the SQL Server, directly edit the cluster_config.json file on the primary the server node. You can directly edit the SQL fields (sql.username, sql.password, and sql.server_url) in the file based on what you need to update.
After updating the file, rerun the interactive installation wizard on the same machine with the updated config as the parameter. You only need to rerun the installation on the primary server.
Updating Kerberos auth
Updating Kerberos auth configuration
To update the common Kerberos Auth configuration, take the following steps:
  1. SSH into any server machine.
  2. Run the following command:
    ./configureUiPathAS.sh identity kerberos-auth global-config update --enabled [kerberos-enabled] --adDomain [ad-domain] --username [default-ad-username] --keytab [default-ad-user-keytab] --lifetime [ticketLifeTimeInHour]./configureUiPathAS.sh identity kerberos-auth global-config update --enabled [kerberos-enabled] --adDomain [ad-domain] --username [default-ad-username] --keytab [default-ad-user-keytab] --lifetime [ticketLifeTimeInHour]
    Note:
    • To manually generate the keytab file, see Setting up Kerberos authentication.
    • The AD domain controller has the Maximum lifetime for user ticket Kerberos setting inside the Default Domain Policy. Make sure the ticket lifetime configured here is not longer than the setting on the domain controller.
    docs image
Console output success
Updating kerberos auth.....Success!
If you wish to utilize SQL Integrated Auth using Kerberos,
please update the SQL connection string to enable Integrated Auth.
For more info on kerberos auth, <link>Updating kerberos auth.....Success!
Console output failure
Updating kerberos auth.....Failed!
Please provide valid kerberos auth configuration values.Updating kerberos auth.....Failed!
Updating AD username and AD user’s keytab for a service group
To update the AD username and/or AD user’s keytab for a specific service, take the following step:
./configureUiPathAS.sh identity kerberos-auth service-config update --sg [service-group] --username [new-ad-username] --keytab [new-ad-user-keytab]./configureUiPathAS.sh identity kerberos-auth service-config update --sg [service-group] --username [new-ad-username] --keytab [new-ad-user-keytab]
The following Service Groups are available (case-sensitive):
  • orchestrator
  • platform
  • discoverygroup
  • testmanager
  • automationops
  • aicenter
  • documentunderstanding
  • insights
  • dataservice
  • processmining
  • asrobots
    Note: To manually generate the keytab file, see Setting up Kerberos authentication.
Updating kerberos config for <service-group> service group.....Success!
If you want to enable sql integrated auth for the <service-group> service goup,
please update the service's sql connection string. For more info on kerberos auth, <link>Updating kerberos config for <service-group> service group.....Success!
Updating kerberos config for <service-group> service group.....Failed!
Please provided a valid kerberos auth configuration values.
For more info on kerberos auth, <link>Updating kerberos config for <service-group> service group.....Failed!
Adding system administrators
One system administrator is created in Automation Suite by default with the username admin on the host organization.
If access to the host organization is lost - for example, if the password for the system administrator is lost or the only users with system administrator accounts leave the company - there is a tool to add or restore a system administrator.
This script does not work if the SQL connection string parameter "Integrated Security=true" exists for platform services.
./configureUiPathAS.sh identity add-host-admin --username [new-admin-username] --email [new-admin-email] --password [new-admin-password]./configureUiPathAS.sh identity add-host-admin --username [new-admin-username] --email [new-admin-email] --password [new-admin-password]
  • --username is a required field.
  • --password is required only if the new administrator uses basic authentication to login.
  • --email is optional unless your external identity provider requires it (for example, Google matches by email, not username).
There are a few important notes about how the administrator is created or restored:
  • New administrators cannot have the same username or email as an existing administrator. If you use the same username or email as an existing administrator, the existing administrator is updated. This is useful if you want to change the password.
  • If an administrator was deleted and you use the same username or email for a new user, the deleted administrator will be restored instead of creating a new one. The password field is not overwritten in this case. An exceptional case is if multiple administrators were deleted with the same username or email, which results in a new administrator being created.
  • If any of the external identity providers configured on the host are forced, that imposes restrictions on the parameters. For instance, if Windows AD is forced, the username must be in the form user@domain. If Google is forced, then email is required.
  • When logging in to a new administrator account for the first time, the password must be changed.
Re-enabling basic authentication
Organization and system administrators may be unable to log in due to an issue with their configured Azure Active Directory or other external identity provider. Organization administrators may be locked out because the Disable basic authentication flag is checked in the Authentication Settings. Organization and system administrators may be locked out because an external identity provider was configured as force/exclusive. This tool will try to re-enable basic authentication for an organization.
This script does not work if the SQL connection string parameter Integrated Security=true exists for platform services.
./configureUiPathAS.sh identity enable-basic-auth --orgname [org-name]./configureUiPathAS.sh identity enable-basic-auth --orgname [org-name]
Note: --orgname is a required field. If basic authentication is restricted at the host level, set the orgname to host.
Updating the TLS protocol
The Istio ingress gateway configured in Automation Suite for routing, communicating between the services, and more uses TLS to secure the exchanges. To prevent any security threats, deprecated TLS protocol version are disabled by default.
Only TLS version 1.2 and higher are currently supported, and if you use a previous version, it is recommended that you upgrade. However, it is still possible to connect using a previous TLS version, but you must first enable it on the Automation Suite server.
Important: TLS 1.0 and 1.1 are deprecated, and enabling these versions can pose a security risk. You are strongly recommended to upgrade to TLS 1.2 or higher instead of enabling lower versions on the server.
To enable an unsupported TLS version, take one of the following steps:
  • To enable support for TLS 1.0 and higher, run the following command:
    kubectl -n istio-system patch gateway main-gateway --type=json \
        -p='[{ "op": "replace", "path": "/spec/servers/0/tls/minProtocolVersion", "value": "TLSV1_0"}]'kubectl -n istio-system patch gateway main-gateway --type=json \
  • To enable support for TLS 1.1 and higher, run the following command:
        -p='[{ "op": "replace", "path": "/spec/servers/0/tls/minProtocolVersion", "value": "TLSV1_1"}]'kubectl -n istio-system patch gateway main-gateway --type=json \
