Last updated Jun 30, 2025
Step 2: Deploying Automation Suite to GCP
Important: You can currently use the GCP deployment template only with Automation Suite 2024.10. We therefore recommend referring to the Automation Suite 2024.10 documentation.
Important: Make sure to go through Step 1: Preparing the GCP deployment before proceeding.
Configuring the deployment
Once you prepare the GCP environment, you can directly deploy the infrastructure.
Take the following steps:
  1. Download the templates from here and unzip them.
  2. (Optional) Move the SSH keys generated at Step 1 in the templates folder.
  3. The unzipped templates include a terraform.tfvars file with the parameters. Edit them according to your deployment.
Deployment parameters
Name
Parameter type
Example
project_id
Project in which the resources will be deployed.
string
my-gcp-project
region
Region where the resources will be deployed.
string
europe-west1
zone
Default zone where zonal resources are deployed. The zone should belong to the region you chose.
string
europe-west1-c
installer_version
Automation Suite installer version.
string
2021.10.3
installer_url
Automation Suite installer URL. It overwrites the installer_version parameter and installs the version from the package.
string
https://download.uipath.com/automation-suite/installer.zip
perform_installation
Automatically install Automation Suite on the provided infrastructure.
bool
lb_fqdn
Fully qualified domain name (FQDN) for Automation Suite.
string
my-fqdn.net
ssh_user
Username used to log in VMs via SSH.
string
user
ssh_pub_key_path
Path to the SSH public key used to access VMs.
string
gcp_key.pub
ssh_private_key_path
Path to the SSH private key used to access VMs.
string
gcp_key
server_instance_type
Instance type of server machines.
string
n2-standard-32
agent_instance_type
Instance type of agents machines.
string
n2-standard-16
gpu_instance_type
(Optional) Parameter used only if the number of GPU agents is at least 1. Instance type of GPU agent machines.
string
n1-standard-16
gpu_type
(Optional) Parameter used only if the number of GPU agents is at least 1. GPU type for the GPU nodes.
string
nvidia-tesla-t4
server_count
Number of server VMs, must be odd
number
3
agent_count
Number of agent VMs.
number
1
gpu_agent_count
Number of GPU agent VMs
number
1
vm_custom_image
(Optional) Name of the custom image you want to use for the VM's. Leave empty to default to latest RHEL 8 GCP image.
string
my-rhel8-image
install_orchestrator
Install Orchestrator.
bool
install_aicenter
Install AI Center.
bool
install_documentunderstanding
Install Document Understanding.
bool
install_insights
Install Insights.
bool
install_data_service
Install Data Service
bool
install_test_manager
Install Test Manager.
bool
install_automation_ops
Install Automation Ops.
bool
install_automation_hub
Install Automation Hub.
bool
install_apps
Install Apps.
bool
install_action_center
Install Action Center.
bool
install_task_mining
Install Task Mining.
bool
install_as_robots
Install Automation Suite Robots.
bool
asrobots_agent_count
Instance type of ASobots dedicated agents.
number
1
asrobots_agent_instance_type
Number of dedicate ASRobots VMs.
string
n2-standard-16
install_process_mining
Install Process Mining.
bool
accept_license_agreement
By setting the parameter as true, you agree to the applicable license agreement.
bool
Advanced configuration
If you want to add any new configuration that is exposed via cluster_config.json, follow these steps:
  1. Use your favorite text editor to edit the ./scripts/inputs_schema file from the unzipped package.
  2. Change or add the json file as required.
    Note: Keep in mind that Terraform will replace ${var} variables defined in the metadata.tf with their respective values when altering the inputs_schema file.
Completing the deployment
Once you set the parameters, take the following steps:
  1. Open a terminal and authenticate to GCP using the following command.
    gcloud auth application-default logingcloud auth application-default login
  2. In the terminal, go to the folder where you unzipped the templates and run the following commands:
    terraform init
    terraform applyterraform init
    terraform apply
  3. Type Yes when asked for approval. The deployment will then run. It usually takes between 1 to 1.5 hours to complete.
  • Configuring the deployment
  • Deployment parameters
  • Advanced configuration
  • Completing the deployment
