- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
Last updated Nov 6, 2025
To start the migration operation, take the following steps:
Move the Identity organization data from standalone to Automation Suite. Details...
Restore the standalone product database. Details...
Back up the platform database in Automation Suite. Details...
Merge the organizations in Automation Suite. Details...
Update the migrated product connection strings.
Migrate standalone Insights. Details...
Delete the default tenant. Details...
