Last updated Nov 6, 2025
Enabling AI Center on the restored cluster
After restoring an Automation Suite cluster with AI Center™ enabled, take the following steps.
  1. Connect to the restored cluster.
  2. Delete the existing secrets.
    1. List the secrets:
      kubectl -n uipath get secrets | grep aicenterkubectl -n uipath get secrets | grep aicenter
    2. Delete the following secrets:
      Kubectl -n uipath delete secrets aicenter-cluster-credentials aicenter-deploy-token-XXXXX aicenter-jobs-token-XXXXXKubectl -n uipath delete secrets aicenter-cluster-credentials aicenter-deploy-token-XXXXX aicenter-jobs-token-XXXXX
      Replace XXXXX with the characters listed at step 2b.
    3. Get the default token name and delete it:
      Kubectl -n uipath get secrets | grep default-token
      Kubectl -n uipath delete secrets default-token-XXXXXKubectl -n uipath get secrets | grep default-token
  3. Go to ArgoCD and sync the AI Center application.
  4. Restart all AI Center-related services:
    kubectl -n uipath rollout restart deployment ai-app-deployment ai-helper-deployment ai-pkgmanager-deployment ai-deployer-deployment ai-trainer-deployment ai-appmanager-deployment
