- Overview
 - Requirements
- Q&A: Deployment templates
 - Install-uipath.sh Parameters
 - Enabling Redis High Availability Add-On for the cluster
 - Document Understanding configuration file
 - Cluster administration
 - Monitoring and alerting
 - Migration and upgrade
- Migration options
 - Troubleshooting
 - How to clear Redis data
 - How to enable Istio logging
 - Unable to launch Automation Hub and Apps with proxy setup
 - Failure to resize PVC
 - Failure to resize objectstore PVC
 - Storage reclamation patch
 - ArgoCD login failed
 - Redis probe failure
 - RKE2 server fails to start
 - MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
 - Pods stuck in Init:0/X
 - Exploring Logs
The Automation Suite cluster is exposing multiple URLs to access the cluster management tools and the suite core functionality, all based on a common FQDN.
You need to configure the DNS for the common FQDN and the subdomains specific to each tool as shown in the following table.
                                  Application  |
                                  Domain  |
                                  Example URL  |
                                  Automation Suite  |
                                  Application Lifecycle Management (ALM)  |
                                  Monitoring / Observability  |
                                  Object Store  |
                                  Docker Registry  |
                                  Insights  |
A Record in Advanced DNS or Management section of your domain as shown in the following table:
                               Type  |
                               Host  |
                               Value  |
                              A Record (or CName)
                              automationsuite (or a subdomain to access Automation Suite)
                              A Record (or CName)
                              *.automationsuite (or a subdomain to access Automation Suite)
See the following example for the configuration:
* wildcard is too generic, add a separate record or rule for the following subdomains: alm, monitoring, objectstore, registry, and insights.
               As a workaround, you can use a private domain for testing purposes only.
For an example, see Sample Azure infrastructure setup.
