- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
Last updated Nov 6, 2025
If you encounter general issues while configuring or using Automation Suite, see the following:
In certain situations, some API calls to Automation Suite can result in a 413 response (or
RequestEntityTooLarge error message). The conditions can occur when:
The request is over 1MB in size.
The HTTP version used is 1.1.
The issues is encoutered in common scenarios like publishing a package from Studio, uploading queueItems, or any other scenario where Activities or Studio are posting files or data to Orchestrator.
Solution
To avoid this issue, you can increase the default buffer limit to a larger value, such as 10MB. To do this, you can change
the Envoy Filter settings to adjust
per_connection_buffer_limit_bytes to a larger byte value.
The following example shows how to set
per_connection_buffer_limit_bytes to 10000000 bytes:
cat > /tmp/increase_buffer_per_connection.yaml <<'EOF'
apiVersion: networking.istio.io/v1alpha3
kind: EnvoyFilter
metadata:
namespace: istio-system
spec:
configPatches:
- applyTo: LISTENER
patch:
operation: MERGE
value:
per_connection_buffer_limit_bytes: 10000000 #10MB
EOF
kubectl apply -f /tmp/increase_buffer_per_connection.yamlcat > /tmp/increase_buffer_per_connection.yaml <<'EOF'
kind: EnvoyFilter
metadata:
spec:
configPatches:
- applyTo: LISTENER
patch:
operation: MERGE
value:
EOF
