- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- AI Center-specific configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
- Exploring summarized telemetry
On this page, we use the cloud templates as a reference point to evaluate the infrastructure costs required to support Automation suite. We also call out a few additional notes to help forecast the total cost of ownership for Automation Suite. The resulting estimates can approximate your future spending on infrastructure with high confidence for cloud deployments. You can also use the estimates as a reference point to compare the costs of physical bare-metal implementations.
Each cloud template deployment automatically provisions a set of components based on the provided inputs.
To calculate the cost of the infrastructure provisioned by the cloud templates based on your scenario needs, refer to the following guidelines and estimates.
There are multiple factors impacting the cost of the infrastructure deployed by the cloud templates, such as the following:
- Number of server nodes
- Server node instance type
- Number of agent nodes
- Number of GPU nodes
- GPU node instance type
- Products selected
You can accurately estimate the cost of your cloud infrastructure by taking the following steps:
- Determine the resources your scenario requires using the UiPath® Automation Suite Install Sizing Calculator.
Use the pricing calculator of your public cloud provider:
Refer to the following examples to help you get started with the pricing calculators.
The following table describes the multi-node HA-ready production infrastructure cost estimate for the Complete product selection in the context of the previously introduced guidelines.
The estimates do not account for the load balancers, Bastion, key vault, and backup.
Number of server nodes |
AWS |
Azure |
3 |
Automation Suite seems to have a considerable infrastructure footprint. However, when comparing it with the total amount of infrastructure needed to run production use cases of standalone UiPath® products, the costs are similar and, in some cases, even lower for Automation Suite.
To give concrete examples of infrastructure cost differences between Automation Suite and standalone products, we leveraged the pricing calculators of cloud providers where possible, along with our hardware requirements. The following table summarizes the results:
Automation Suite Milestone |
Product |
Monthly cost in standalone |
Monthly cost in Automation Suite |
Yearly cost in Automation Suite |
Link to estimate in Azure |
Enterprise grade Orchestrator |
Orchestrator |
$2,250 |
$2,813 |
$33,756 | |
Coming from standalone |
Orchestrator |
$2,850 |
$3,144 |
$37,728 | |
Test Manager | |||||
Insights | |||||
Action Center | |||||
Modern basic platform |
Orchestrator |
N/A |
$3,476 |
$41,712 | |
Insights | |||||
Data Service | |||||
Automation Hub | |||||
Automation Ops | |||||
Apps light |
Orchestrator |
N/A |
$3,476 |
$41,712 | |
Apps | |||||
Modern platform with Apps |
Orchestrator |
N/A |
$3,808 |
$45,696 | |
Insights | |||||
Apps | |||||
Full platform + Document Understanding Starter |
Orchestrator |
N/A |
$4,139 |
$49,668 | |
Insights | |||||
Apps | |||||
AI Center | |||||
Document Understanding | |||||
Scale to Document Understanding for every 50k pages/day |
Extraction |
$100 |
$1,200 |
D4 VM | |
Classification |
$100 |
$1,200 |
D4 VM | ||
OCR |
$100 |
$2,400 |
NC4 VM | ||
Task Mining |
Task Mining on dedicated agent |
N/A |
$531 |
$6,372 |
B20Ms |
Process Mining |
Process Mining on dedicated agent |
N/A |
$498 |
$5,952 |
F16s v2 + SQL license |
Automation Suite Robots |
Automation Suite Robots on dedicated agent |
N/A |
$496 |
$5,925 |
F16s v2 |
In addition, the total costs of supporting Automation Suite are lower compared to standalone product deployments when considering the following:
- Automation Suite requires fewer staff members to maintain operation since fewer machines must be managed as compared to standalone products.
- The IT department does not require any new skills to support additional products because the Automation Suite instance management is the same regardless of which products are used. Therefore, Automation Suite required less IT staff to support the range of UiPath® products.
- The infrastructure spend does not change significantly when adding new products to the Automation Suite instance and increasing its ROI (i.e., when adding Automation Hub).
- Automation Suite also includes out-of-the-box monitoring, cluster management, as well as unified admin and end-user experiences across all products.
