Last updated Dec 19, 2025
Manual: Installing Automation Suite
The following table lists the steps you must perform for Automation Suite installation:
Steps
Single-node installation
Multi-node installation
Lite mode
Prerequisite
available
available
available
Step 1: Accepting the license agreement
available
available
available
Step 2: Installing the Infrastructure on the first server machine
available
available
available
Step 3: Installing the infrastructure on the other server machines
not available
available
available
Step 4: Installing the infrastructure on all the agent machines
not available
available
available
Step 5: Hydrating the in-cluster registry for offline installations
available
available
available
Step 6: Completing the installation
available
available
available
Prerequisite
Configure the KUBECONFIG environment variable to point to the RKE2 Kubernetes configuration file and update the PATH environment variable to include the RKE2 tools directory using the following export commands:
export KUBECONFIG=/etc/rancher/rke2/rke2.yaml
export PATH=$PATH:/var/lib/rancher/rke2/binexport KUBECONFIG=/etc/rancher/rke2/rke2.yaml
Before running the installation, make sure to read the license agreement.
To accept the license agreement, choose one of the following methods:
  • Option 1 (Environment variable) - Set the LICENSE_AGREEMENT environment variable to accept by running the following command:
    export LICENSE_AGREEMENT=acceptexport LICENSE_AGREEMENT=accept
  • Option 2 (Inline parameter) - Append --accept-license-agreement to every execution of uipathctl.
Step 2: Installing the infrastructure on the first server machine
To install the infrastructure on the first server machine, navigate to the installer folder and run the following command:
cd /opt/UiPathAutomationSuite/<version>/installer
./bin/uipathctl rke2 install -i /opt/UiPathAutomationSuite/cluster_config.json -o ./output.json -k --accept-license-agreementcd /opt/UiPathAutomationSuite/<version>/installer
Note:
  • The -k parameter installs the infrastructure on the first server machine.
  • Once the infrastructure is installed, the server machine becomes a node in the Automation Suite cluster.
To expand the Automation Suite cluster, install the infrastructure on the additional server machines.
To do that, run the following command on all the additional server machines:
./bin/uipathctl rke2 install -i /opt/UiPathAutomationSuite/cluster_config.json -o ./output.json -k -j server --accept-license-agreementcd /opt/UiPathAutomationSuite/<version>/installer
Note: The -j server parameter adds the machines as server nodes to the existing Automation Suite cluster. The fixed_rke_address flag in the cluster_config.json file connects the exiting Automation Suite cluster.
If you have additional agent machines, you must install the infrastructure on those machines and add them as agent nodes to the Automation Suite cluster.
To to that, run the following command on all the agents machines:
./bin/uipathctl rke2 install -i /opt/UiPathAutomationSuite/cluster_config.json -o ./output.json -k -j agent --accept-license-agreementcd /opt/UiPathAutomationSuite/<version>/installer
Note:
This step is required only if you use in-cluster registry for offline installations.
To seed the in-cluster registry from the temporary registry, run the following command:
./bin/uipathctl rke2 registry hydrate-registry /opt/UiPathAutomationSuite/cluster_config.jsoncd /opt/UiPathAutomationSuite/<version>/installer
If you are setting up Automation Suite with Document Understanding modern projects enabled, use the --serial option with the hydrate-registry command to prevent out of memory issues:
./bin/uipathctl rke2 registry hydrate-registry /opt/UiPathAutomationSuite/cluster_config.json --serial./bin/uipathctl rke2 registry hydrate-registry /opt/UiPathAutomationSuite/cluster_config.json --serial
At this point, all the nodes should be interconnected to establish the infrastructure for installing Automation Suite.
To complete the installation, take the following steps:
  1. Verify if all nodes are available on the first server node, by running the following command:
    kubectl get nodeskubectl get nodes
    The output of the aforementioned command should look similar to the one shown in the following image. Note that the total number of nodes must match the sum of server and agent nodes.
    docs image
  2. Create the prerequisites required for the shared components installation, by running the following command:
    ./bin/uipathctl prereq create /opt/UiPathAutomationSuite/cluster_config.json --versions versions/helm-charts.json./bin/uipathctl prereq create /opt/UiPathAutomationSuite/cluster_config.json --versions versions/helm-charts.json
    These are primarily object storage buckets and SQL databases. The SQL databases required for the installation are created on the SQL server if the sql.create_db key is set in the config file. The object storage buckets are created in the cloud provider if the object_storage.create_bucket key is set in the config file.
  3. Validate the prerequisites required by the shared components installation, by running the following command:
    ./bin/uipathctl prereq run /opt/UiPathAutomationSuite/cluster_config.json --versions versions/helm-charts.json./bin/uipathctl prereq run /opt/UiPathAutomationSuite/cluster_config.json --versions versions/helm-charts.json
  4. After verifying the infrastructure, install the shared components and the services by running the following command:
    ./bin/uipathctl manifest apply /opt/UiPathAutomationSuite/cluster_config.json --versions ./versions/helm-charts.json./bin/uipathctl manifest apply /opt/UiPathAutomationSuite/cluster_config.json --versions ./versions/helm-charts.json
