- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- AI Center-specific configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
- Exploring summarized telemetry
cluster_config.json file. You can configure app security using the app_security_mode setting. This is an overview of the possible values of the app_security_mode setting.
system_managed option.
Value |
Description |
system_managed (default)
A SQL user is created automatically per process app. This ensures that users editing transformations in Process Mining can only query data that belongs to the process apps for which they have edit permissions.
Note:
This requires SQL authentication on the Process Mining data warehouse SQL Server. The SQL user used in the connection strings used to connect to the
AutomationSuite_ProcessMining_Warehouse database must have at least the following server-level and database-level roles both during and post-installation to enable
per app security:
One account is created that is used for all process apps. This means that when editing transformations in Process Mining, users can query data from other process apps. Note:
AutomationSuite_ProcessMining_Warehouse must have at least the following database-level roles and permissions both during and post-installation to enable per app
security:
Turn on SQL Authentication for the Process Mining data warehouse SQL Server. See the official Microsoft documentation on Change server authentication mode.
Grant ALTER ANY LOGIN to the provisioning user of Process Mining.
Grant access to the
masterdatabase to the provisioning user of Process Mining.Attention:The SQL user used in the connection strings used to connect to themasterdatabase must have enough permissions to create login, users and roles.
