- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- AI Center-specific configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
- Exploring summarized telemetry
Last updated Nov 13, 2025
This table compares the feature availability across the following deployment methods:
- the AWS, Azure, and GCP cloud templates, which provision the infrastructure and install Automation Suite in a short amount of time. Templates are the recommended option.
the manual installation provisioning method, which requires more technical expertise and is considerably more time-consuming.
Feature
AWS template
Azure template
GCP template
Manual installation provisioning
Deploy to existing Virtual Network
Single-node evaluation vs. lite mode vs. multi-node HA-ready production
Can set number of instances
Air-gapped
A-la-carte product selection
Custom domain (cloud-provided DNS service or not)
Custom certificates
Deploy to existing SQL Server
Hardware requirements validation
Template uses cloud-native availability zones
N/A
Proxy configuration
Optional bastion host
N/A
Instance refresh
N/A
Backup and restore cluster
N/A
Remove nodes
N/A
