Last updated Nov 13, 2025
Node becomes unresponsive (OOM) during large Document Understanding bundle upload
Uploading large Document Understanding offline bundles may cause a node to become Not Ready due to an out-of-memory (OOM) condition. The issue occurs because the image seeding process loads large image layers into memory in parallel, which results in high memory consumption. This typically affects multi-node environments where the seeding operation is performed directly from a node.
Solution
To address the issue, you must seed the images sequentially with a single worker thread. This reduces memory usage and prevents the node from running out of memory.
Take the following steps:
  1. Unzip the offline bundle to extract the image tar file (for example, /uipath/tmp/offline-bundle.xxx/sf-images/images.tar).
  2. Obtain Docker registry credentials (docker_registry_username and docker_registry_password) from the cluster configuration (infra.docker_registry) or the Kubernetes secret uipath/docker-registry-credentials.
  3. Use the following script to seed the images one registry pod at a time with a single worker thread:
    function get_registry_addresses() {
      local namespace="docker-registry"
      local lh_registry=1
      local server_node_count
      lh_registry=$(kubectl get deployment -n "${namespace}" docker-registry --ignore-not-found --no-headers | wc -l)
      server_node_count=$(kubectl get nodes -l "node-role.kubernetes.io/master=true" --no-headers | wc -l)
      IFS=" " read -r -a registry_addresses <<<"$(kubectl get pods -n ${namespace} -o jsonpath="{.items[*].status.podIP}" -l app=docker-registry)"
      if [[ "${lh_registry}" -eq 1 ]]; then
        [[ "${#registry_addresses[@]}" -eq 1 ]] || error "Failed to get address of registry pod."
      else
        [[ "${#registry_addresses[@]}" -eq "${server_node_count}" ]] || error "Failed to get address of all registry pods."
      fi
      echo "${registry_addresses[@]}"
    registry_addresses=($(get_registry_addresses))
    for ip in "${registry_addresses[@]}"; do
      ./bin/uipathctl registry seed \
        --tar-file "<tar_file_path>" \
        --dest-registry "${ip}:5000" \
        --dest-password "<docker_registry_password>" \
        --dest-username "<docker_registry_username>" \
        --log-level debug \
        --num-worker 1
    donefunction get_registry_addresses() {
      local lh_registry=1
      else
      fi
        --log-level debug \
        --num-worker 1
    done
    Make sure to replace <tar_file_path>,<docker_registry_password>, and <docker_registry_username> with the appropriate values.
  • Description
  • Solution
