OUT OF SUPPORT
Automation Hub User Guide
Last updated Nov 11, 2024
Release date: 3 November 2021
What's New
We are proud to announce that UiPath Automation Hub is now available to be installed on premise, in the customer's local environment, or Virtual Machines on Azure, Amazon Web Services, or Google Cloud Platform​.
This version of UiPath Automation Hub is available only via the UiPath Automation Suite, which enables you to install the full UiPath Suite of products on premise.
The main benefits of the UiPath Automation Suite are as follows:
  • All UiPath products in a centralized on-premises location
  • Same interface and features as in the Software as a Service version
  • Back-up and Restore
  • Monitoring and Alerting
  • High Availability
What's included in the build?
All features included in the UiPath Automation Hub 2021.4 release, like:
  • Customized High Level Assessment
  • UiPath Automation Store
All the features that were delivered in cloud until August Release:
  • Dark Theme support
  • New Languages Support
  • Idea Tags
What's not included in the build?
The rest of the items that are planned for 2021.10 cloud release but will not be included in the build:
  • Customized Detailed Assessment
  • Task Mining Integration
  • Studio Integration
  • Assistant Integration
Getting Started
Start by checking the Hardware requirements and afterwards, you can check more details on how to perform the installation:
Release date: 1 November 2021
Automation Suite Availability
Ten products, one platform.
The newest UiPath deployment model called Automation Suite gathers the functionality from Automation Cloud and compresses it in a sole installation, allowing you to set up Automation Hub and several other products in an on premises or cloud-hosted environment.
Learn more about Automation Suite.
